Results 1 to 6 of 6
Thread: Strange Throttle Noise
    Mar 2009
    1999 black vx 0179
    I started getting a sucking/rattling raspy noises coming from my throttle when its closed or almost closed and it really bad when i shut her down hot or cold but when open no noise if i open it up some be for i turn her off no noise. any ideas because i'm out of them
    Sucking would indicate a vacuum leak most likely, but I would also imagine you would have a CEL already or soon. If it's rattling, I would guess that is a different issue altogether, unrelated. Open throttle is probably just hiding the same sound w/ engine noise. Hard to say without digging in there.
    Mar 2009
    1999 black vx 0179
    for now i think i'm going to pretend to not hear it
    Wrench
    One known source of weird rattling noises is the heat shielding that is clamped to the exhaust system in several places.
    Crawl under & trace the exhaust front to back, bet you'll find at least some of the problem...
    Another thing I'd look at is the 22mm nut that holds the tube to the bottom of the EGR valve.
    Mar 2009
    1999 black vx 0179
    not sure theres any heat shielding left haven't check the egr valve
    May 2009
    1999 Ebony Black/Red
    +1. i have the same problem. when car is cold, upon slow accelerating you can hear that strange kinda rattling air noise. the problem was located: that nut on EGR valve was tighten incorrectly (twisted) allowing air to come out. i was told when the engine gets to working temp, the egr valev shuts and that explains why the sound disappears
  1. strange vehicle
    By pbkid in forum VX Talk...
    Last Post: 06/24/2009, 09:58 PM
  2. Throttle body mod?
    By volume311 in forum VX Modifications...
    Last Post: 05/14/2006, 04:34 PM
  3. Strange noise
    By TimG in forum VX Troubleshooting...
    Last Post: 08/30/2005, 01:58 PM
  4. throttle
    Last Post: 05/02/2003, 10:44 AM
  5. Strange engine noise when accelerating
    By VX crazy in forum VX Troubleshooting...
    Last Post: 10/24/2002, 07:24 AM
