Results 1 to 3 of 3
Thread: OBD2 plug
    Oct 2009
    2001 Mica Green VCS 0403
    OBD2 plug
    Check engine light is on. Trying to find the OBD2 plug, where is it located.
    Thanks in advance,
    Soggy.
    Oct 2005
    '01 ebony VX 1427
    Open your dr. door on side of dash you will find the fuse panel the plug points down from under the dash directly under the fuse panel.
    That which does not kill me only makes me stronger.
    Oct 2009
    erland,
    Thank you,
    Soggy
  1. OBD2/DTC Reader + Code Recognition help please
    By crotchrocket in forum VX Troubleshooting...
    Last Post: 02/14/2009, 09:45 AM
  2. Oil in spark plug well
    By ojmagg in forum VX Troubleshooting...
    Last Post: 04/24/2008, 12:47 PM
  3. where does this plug go?
    By spitfire5454 in forum VX Talk...
    Last Post: 10/13/2004, 04:19 PM
  4. Best OBD2 Software?
    By WyrreJ in forum VX Modifications...
    Last Post: 04/25/2004, 09:40 AM
  5. Oil Drain Plug Help
    By DeafVX in forum VX Talk...
    Last Post: 08/16/2003, 12:11 PM
