Results 1 to 9 of 9
Thread: OME 912 OOPS x 2 ?
    Oct 2006
    01 Green Dragon 00291
    OME 912 OOPS x 2 ?
    Installed OME 912 springs yesterday . I'm pretty sure that I installed them Upside down. I put the flat side off the spring down. My logic being that the flat side had sharp edges that may cut the rubber damper . Thing is with the flat side down , when rotated to fit the cup on the axle it seems to not seat very well .
    Moving on ... I Ordered 1.5" lift , after install I'm measuring a lift of 2 13/16 " . Is this Right... Can't be... .
    Wrench
    Quote Originally Posted by tjh View Post
    Flat side UP...
    Look at how the bottom cup fits the taper of the coil, & how the flat side matches the upper cup = flat.
    Oct 2006
    Thanks
    That is exactly what I thought .
    Just think though...by the time you are done with the re-install you should be an expert and be able to do it in no time at all!
    Practice makes perfect!
    I don't know, I think I would just leave it and get the extra 1" for free. I'm sure it's just a conspiracy by the suspension companies to make you think you can't do it.
    After you of course lol.
    97 Jap Import, Black BEAST
    think mine are upside down, lol only been a year !
    Oct 2006
    Update : Today I flipped the OME 912 springs , and I'm still measuring a lift of 2 13/16 " .
    So how much lift does the three inch lift springs give ? Three inches , or is it more ? or maybe less ?
    The 912s give about a 2.5 inch lift. Yours will probably settle a bit.
    2000, Kaiser, 0134
    I installed mine upside down, and the puck at the bottom my first time
  1. Oops I am going to need some new body panels
    By Bee Sting in forum VX Talk...
    Last Post: 12/17/2008, 11:02 PM
  2. oops....
    Last Post: 10/20/2007, 12:14 AM
  3. Oops, I did it again... (car stereo)
    By PHO2GR4 in forum VX Modifications...
    Last Post: 02/19/2007, 09:20 AM
  4. Oops
    By Anita in forum VX Talk...
    Last Post: 12/17/2004, 04:50 AM
  5. Oops II
    By lttlbddy in forum VX Talk...
    Last Post: 12/16/2004, 05:44 PM
