Results 1 to 7 of 7
Thread: Trimming the body Cladding
    May 2003
    200o, proton, VX
    Many of you have talked about trimming the body cladding to fit larger tires on the car. I was wondering if someone could explain this procedure a little and maybe provide some detailed pics?
    Mar 2003
    For the most part, the trimming of cladding is to clear the tires when you are turning. If you look at the cladding in front of the front wheels, the very tip of the lowest, inner point of the cladding will touch the tread of larger tires if not lifted. Sorry I don't have pictures, but if you go to your beloved VX, turn the steering wheel 1/8th to 1/4th turn, the outer edge of the tire comes closest to the bumper... from this, you should be able to imagine how a larger diameter tire would come even closer. I have the Nitto Terra Grappler 285/60/18's and the don't rub at all... and unless you look close, you can't tell the cladding was even trimmed. Hope that helps.
    TTYL!
    Coach... aka Randy! (I often forget who I really am!)
    My 2000 Ironman VX!... Nitto Terra Grapplers 285/60/18's on stock 18" rims, Power Vault Muffler, Tone Monday's custom tow package, OME 912 Springs, custom audio/video/multimedia computer system in the works! Transformation to LS1 V-8 Power as we speak!
    My Webshots Gallery...
    1999, Ebony Black, VX ,1976
    here is a pic. i just used a hand saw.
    http://www.vehicross.info/gallery/da...c00066-med.jpg
    1COOLVX
    03' Dodge Dakota Quad Cab
    I used a pocket knife in the parking lot of the tire shop after putting on 265/75/R16's
    took all of about 2 minutes.
    3C FORMERLY VX #1876
    www.triple-cs.com
    Sawzall, need I say more! Like cutting butter, just don't let it get away from you!
    Yep, after getting my 18x8.5 Enkei's, I had to whip out the sawzall. Not for the front of the well, but the back. Piece of cake, but man, you sure feel awful while doing it.
    But I MEANT to cut the metal!! ;Dp; ;Dp; ;Dp;
    ;eekp; ;eekp; good times yeah!
  1. Cladding: Trimming and BFH question
    By c09<[865P in forum VX Modifications...
    Last Post: 08/29/2010, 07:06 PM
  2. trimming cladding
    By SomeBeach in forum VX Talk...
    Last Post: 05/27/2009, 10:48 PM
  3. Trimming the front cladding
    By MSHardeman in forum VX Troubleshooting...
    Last Post: 03/24/2006, 11:11 AM
  4. Will these fit my 01 18's with NO trimming?
    Last Post: 05/12/2005, 06:24 PM
  5. reapir body cladding
    By PWX1 in forum VX Troubleshooting...
    Last Post: 06/21/2003, 08:06 PM
