Finally last WKD I installed a new set of OME 912 springs, flipped the ball joints and cranked the torsion bars to add a few inches to my beloved VX. Thanks to the many posts here about where to buy and how to perform it all (and the detailed description about the ball joint flip from Planet Isuzu…) It all was finished in less then 3 hours utilizing a friend’s Body Shop (Having air tools makes life a lot easier). HOWEVER, a few hours after I finished the lift, I noticed a strange grinding sound… took it to a mechanic on Sunday that thinks it’s coming from one of the bearings in the rear differential (I have less then 25k miles on my VX…). I will probably spend the coming WKD taking it all out to see if the noise continues and if it does, will probably go to the dealer next week.
Did any of you who have done this lift had this happen to him?
