Results 1 to 9 of 9
Thread: More responsive brakes with less pedal travel
    Dec 2004
    1999, Black, Vehicross, 1984
    I am looking to fix the brakes on my VX. I figure replacing the pads, rotors, and lines should make them more responsive and engage sooner rather than nearly putting my foot to the floor. Will this also alleviate pulling to the left or is the right caliper failing? I have been browsing ebay but thought I would get some feedback from the members here. There seems to be a few options there but to be honest it mostly looks like cheap junk. Can anyone attest to a good set of stainless steel braided brake lines or other brake parts?
    i got my stainless steel lines from indy4x4, ive had them on at least 2 years, maybe longer but they are great
    oem pads are the way to go
    I have the stainless braid lines from Indy4X & am happy with them...
    https://id211.chi.us.securedata.net/...roducts_id=295
    I also have Magnum cross drilled rotors from eBay & I like them too, though their "corrosion resistant paint" isn't all that corrosion resistant in my experience...
    http://srx.main.ebayrtm.com/clk?RtmC...150171&pi=3907
    Were I to do it again, I'd spend a few extra bucks & get the optional cadmium plating.
    After installing new pads, (I prefer OEM, but many say any ceramic pad should be the same) rotors, & lines, if it still pulls or has "pedal issues" is when I'd start looking at caliper replacement and/or possible master cylinder replacement.
    This is assuming that the brake system has been bled properly. (search "brake bleeding")
    http://vehicross.info/forums/showthr...brake+bleeding
    01, LineX tan/black, 1055
    x2
    I had similar braking problems, I pulled the ABS fuse, brakes seem much better now. I also had the front end torn apart, so it could be coincidence and a caliper was frozen or something, but I had even wear on the pads, so I don't think so.
    Dec 2004
    The Indy4x lines look good. Thanks for the info. I was thinking maybe the guy had air in the lines but having never changed the brakes it did not seem likely.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    I have a set of indy lines I'm getting rid of BTW. The red plastic covering is coming off of one of them, but they are otherwise in great shape. I actually had to replace one with a locally made DOT approved line which I personally feel is much higher quality. I can send you some pics if interested. $100 shipped and they're yours.
    2001, Dragon Green, 1342
    I did the R1 rotors, OEM pads, and the stainless steel brake lines. Which one improved the brake pedal, I don't really know. Expect it was the brake lines but it certainly helped. As far as the pulling, I have that too, both left and right, before and after the brake job. Damned if I know why.
    Diving to one side or the other is also a sign of bad shocks.
    Feb 2009
    1999,silver, 1516
    Mine pulls pretty good if there's just the slightest rut in the road. Something about the big ole grips make it wanna wander.
  1. How much rear wheel travel do we have?
    By Marlin in forum VX Troubleshooting...
    Last Post: 12/29/2010, 08:13 AM
  2. Travel Ural 2007
    By ibmx2 in forum Chit-Chat ...
    Last Post: 10/07/2010, 07:52 AM
  3. VX Travel story in West Africa.
    By kodiak in forum VX Talk...
    Last Post: 01/16/2009, 05:54 PM
  4. Useful Shock Travel
    By BD-VX99 in forum VX Modifications...
    Last Post: 11/30/2005, 01:28 AM
  5. Anyone a travel agent?
    By Tone in forum VX Talk...
    Last Post: 04/12/2003, 06:12 AM
