Results 1 to 5 of 5
Thread: Coolant Leak question
    Feb 2010
    2001,Kaiser,1130
    Hi guys,
    I found my 01 Kaiser on this forum in mid March. I've been living with this slow leak. I've gotten an estimate of $830 to do the water pump and the timing belt (and all the appropriate seals) from an Ex-Isuzu dealership here in the Twin Cities. I would do this myself, but I haven't got access to a garage, nor do I have the monetary leeway to screw anything up. I'd like to be sure its the water-pump, so I took some pictures of the leak. It seems to leak only when its NOT running, but even when its been sitting for a few days.
    I haven't been able to figure out what this steel pan that is being leaked over is. Its between the oil filter and the oil pan, at the bottom of the engine.
    I'd like to know what you guys think, is it probably the water pump or thermostat?
    Wrench
    My guess would be water pump.
    If you follow your upper radiator hose back to where it disappears under the intake plenum, you'll see where the thermo lives.
    Look around the base of the thermo housing with a flashlight to see if any coolant is visible.
    Edit...
    My mistake, it's the LOWER radiator hose that's connected to the thermo housing.
    Jul 2004
    2000, Kaiser Silver, 0196
    Quote Originally Posted by atilla_the_fun View Post
    Dead giveaway - it's the water pump shaft seal. Have at it!
    Just out of curiosity, how many miles on the clock when it started leaking?
    Feb 2010
    2001,Kaiser,1130
    Thanks for the info,
    I bought it leaking, the seller made sure not to tell me about it. Got a good deal so he must have been scared about the repair. I only discovered the leak after getting home. I'll bet it was around 92-93K miles. I drove it 1500 miles after I found the leak and didn't lose a drop during the drive.
    Jul 2004
    Yeah when it's just sitting there with a cold engine it's relying solely on pressure from the spring and the smooth surface of the seals to keep water from leaking past but when the seals start to go, bearings get a little play in them, etc. that spring pressure alone won't get the job done and water sneaks past the seals and out the weep hole. When it's running, however, there is additional pressure from the wet side which helps seal things up - it pushes on the impeller forcing the faces of the hard seal together tighter and also pushes on the rubber between the shaft and the rotating part of the hard seal, making it less likely water can sneak between the shaft and the rubber seal. If you want to see it leak faster, take the radiator cap off and let it run with the cooling system at atmospheric press. - that way you have the second worst case scenario for leakage - a spinning shaft but no pressure to help the seals. The worst case of course is when the seals get so bad pressure doesn't help, it hurts. Then you're blowing out water while driving, which can get you stranded on the side of the road, overheated, warped heads, etc. A pump will last quite some time in that first phase of failure but when it starts leaking under pressure - hosing down the bearings with hot water, the rumbling begins and things fall apart pretty fast after that. You don't know when the leaking started, so you have no idea how close you are to the catastrophic phase...
    Just in case the seller tried to "fix' the leak with some of that Stop Leak stuff, you might want to consider adding some cooling system cleaner a few hundred miles before you take the vehicle in for service, then (provided your temp gauge stays in normal range - i.e., you haven't been experiencing overheating probs) a day or two before service, drain the system and replace with plain water to flush everything out. Ordinarily you wouldn't want to run plain water since the seals depend on coolant for lubrication but you're replacing the pump anyway so it doesn't matter...
  1. Antifreeze / coolant leak... GRRRRRR!!!!
    By ZeroSix in forum VX Troubleshooting...
    Last Post: 08/13/2012, 05:20 AM
  2. Coolant Leak, Alternator Died... NEED HELP!
    By UWVX89 in forum VX Troubleshooting...
    Last Post: 03/09/2012, 06:49 PM
  3. Coolant leak
    By VXNIT in forum VX Talk...
    Last Post: 10/02/2010, 08:52 PM
  4. Coolant leak! Help!!!
    By ron in forum VX Troubleshooting...
    Last Post: 04/25/2009, 12:56 PM
  5. Coolant leak ?
    By VXNIT in forum VX Troubleshooting...
    Last Post: 02/26/2009, 08:34 AM
