Results 1 to 9 of 9
Thread: A/C compressor ? 2001 vs 2000 vs 1999
    My compressor is making a belt squeal on start up so I'm going to replace it.
    I talked to Merlin and he said theirs is too much.
    Looked on ebay and I can buy new one's all day long but they specify 1999 to 2000 (doesn't say 2001).
    Is the 01 version different?
    Here's a link
    1999 Astral Silver VehiCROSS #1214
    If you can't find a replacement compressor right away, you can go with a shorter belt and by-pass the compressor. I had to do this when mine seized up in Uwharrie. I don't remember a part number, but I do remember it was just about 5 inches shorter.
    You probably don't want to go very long without AC in Houston though, huh?
    ________
    RoyalBrunette
    I found a guy who claims to have a used one in stock for $150 if you want to go that route...
    I'm PM'ing the info to you.
    ________
    Sex advice forums
    2001, Ebony Black, 1153
    Quote Originally Posted by phines View Post
    My compressor has been chirping at start up and has been whining for years, if he doesn't want the info I do!!!!!
    I found 4 different places that said they had a used compressor off of an '01 VX, so unless johnny buys all 4 you should be able to get one too.
    He can relay that info to you, or I will once he decides what he's doing.
    ________
    Ncis forum
    From the link LDUB provided, it appears I would be best with a 2001 Trooper compressor.
    Thanks for all the help, and I will post how it turns out.
    JM
    and now the part stores can't find the Trooper compressor in the computers....
    Autozone is telling me their 2000 Trooper compressor is the same as the 2001 (which they cannot order), and they can get the 2000 model.
    He did ask if it's two or four wheel drive? b/c it will use a different belt?
    Any advice?
  1. 2001 vehicross a/c compressor FIX
    By pilchercross in forum VX Troubleshooting...
    Last Post: 01/13/2013, 07:40 PM
  2. Differences between 1999 and 2000 models
    By mrlegoman in forum VX Troubleshooting...
    Last Post: 02/12/2008, 09:24 PM
  3. 99 2000 2001 advantages?
    By victor in forum VX Talk...
    Last Post: 09/27/2007, 06:40 PM
  4. 2001 6VE1 in a 1999 VX
    By majork in forum VX Modifications...
    Last Post: 02/12/2007, 10:17 PM
  5. 1999, 2000 or 2001 - Which model is best?
    By SnydertheHun in forum VX Talk...
    Last Post: 08/11/2006, 05:07 AM
