Results 31 to 45 of 58
Thread: Lower Gear ratio better mpg?
  1. #31
    Jun 2008
    2001,black, vehicross 1353
    Quote Originally Posted by BigMeatVX View Post
    Is this guy for real? LOL
    Get out your. 4" angle grinder and you could fit Dana 60 ring and pinion to fit, I hear....LOL
    I for one have achieved over 21 MPG on a VX....and it is done exactly as. Riff Raff explained...
    A lightweight tall skinny (contact patch) tire will deliver....and locking up the Torque Converter helps a lot, too.
    I had great luck with Yokohama 315/75/16. And Buckshot Mudders 78-16....narrow but 36" tall!
    As for the spelling bee....I use a tiny PDA with big fat fingers, to post and reply, so if I make a mistake....I just usually leave it, cause its easier than tryin to fix it on this micro keyboard....LOL
    Not to highjack this thread or anything. . .but
    Hey Big Meat, may I get some more info in regards to your achievement of 21 mpg, Locking up the torq converter is done how?.... Maybe we need a MPG improvement thread - or maybe there is one already. I'm no greeny by any means but a suv this small, with a 6 cylinder ought to get better than the 10- 12mpg I get.
    Milwaukee WI
  2. #32
    2000 IronMan #11
    Without doing any ratio changes of my 10-11% increase in tires...I roll about 15.7 average per tank. I ride 265.75.16. My procomp rims are not too light. I have acheived 17-18 before but the work involved was not worth my time. It concerned acetone.
  3. #33
    Jun 2008
    I don't understand exactly what you mean.
  4. #34
    2000, Kaiser, #0016
    Quote Originally Posted by djvx View Post
    There is a recent urban myth about adding small amounts of acetone to gasoline to increase its efficacy.
  5. #35
    Mar 2010
    2001 Ironman 0588
    VX PROs - What's the max tire height before having to trim the cladding?
    I made a quick little spreadsheet calculator. Here is a preview:
    TireSizeCalculator.xls
    Modify? Improve? Delete?
  6. #36
    2000 IronMan #11
    There is a whole nuther thread on that. I personally raised mine. No side effects. Trust me, before messing with my VX I did the RESEARCH. It works but...the time, and the money spent on the acetone isn't too worth it for me. I have thought about trying it again but have yet to come close. Find the old thread and post questions there.
  7. #37
    There are too many variables, re: different wheel offset/width, for a definitive answer to this question.
  8. #38
    Mar 2010
    2001 Ironman 0588
    Dang it! Of course that will make a difference.
  9. #39
    Wink
    Quote Originally Posted by l.groves View Post
    Then praise almighty Ldud is a genious. All hale Ldud!!! Oh yea did you go back and correct your spelling yet.
    Anyways, enough caffeine venting. I found out the the rear size ring gear is 220mm (8.66"). I did find a kit that changes Isuzu to a DANA 44 which would give more options on ratio's. Only It may only be for smaller gear sets. I'll have to call and find out for sure.
    Oh...almost fergetted...
    Isuzu DID use a Dana 44 rear axle in some models.
    I dunno where you're seeing this conversion kit, but I'm all ears, speshully iffin it'll work on the front axle...
    BTW...now that I've had more time fer thinkin' on it & such, I figger I might just use "Then praise almighty Ldud is a genious. All hale Ldud!!!" as my new siggy line...
    Of course, I'd need your permission, & I'd prolly take another whack at the spelling on that "G-word"...
  10. #40
    Aug 2008
    As L-Dub indicated there are many variables. However; on a 100% Stock "non-lifted" VX, the maximum tire O.D. hovers between 32.6" -- 33.3". The key is to use the skinniest/narrow tire available and the Stock OEM rims when using 16" or 18" tires. Use the narrowest rim width allowed for 15, 17, 20, 22 size tires. The skinnier the tire and the narrower the rim width, the less likeyhood trimming will be required on the VX cladding.
    Here are the skinniest & tallest tires that will fit without "lifting" by rim size:
    33/9.50-15LT (32.7" O.D.) (i.e. BFG - A/T)
    255/85R16 (33.3" O.D.) - Use with 1999 VX rims (16x7)*
    285/70R17 (32.7" O.D.)
    265/70R18 (32.6" O.D.) - Use with '00/'01 VX rims (18x7)
    275/70R18 (33.0" O.D.) - Use with '00/'01 VX rims (18x7)
    275/60R20 (32.9" O.D.)
    285/50R22 (33.2" O.D.)
    * The winner is 255/85R16 (33.3" O.D.) mounted on 1999 OEM 16x7 VX rims. Your VX will look like a Stage-Coach with wagon wheels from the 'ol West, but there's your answer.
    Disclaimer: The tire sizes listed above may or may not require cladding trim. Since VX's were hand-made; no two VX's are exactly alike and what clears on one VX may rub on another VX. Still, the above tires will fit on a 100% Stock "non-lifted" VX with little effort.
  11. #41
    Jul 2004
    1999/black/VX/black
    one is considered the wiki-tire-pedia
    LOL
  12. #42
    Apr 2010
    2001 VEHICROSS WHITE 1297
    TANKS
    TANKS AND THE NEXT TIME I WILL OPEN A NEW FORUM... I JUST NEED TO KNOW HOW
  13. #43
    Apr 2010
    1999 silver
    I called about the DANA 44 kit and it will not work on the vehicross 12 bolt. No other ratio's are available that would make a difference. 4.10 only but would be of little benefit for mpg. Thus ends my quest....
  14. #44
    There are some options for the rear...4.77 which are rare and hard to find (a pair is for sale now on planetisuzoo.com) and 5.38's from Indy 4x. No 5.38 for the front 10 bolt though...unless you do a SAS with a Waggy D44.
  15. #45
    2001, Ebony Black, 1153
    Yes, that is exactly what everyone was trying to tell you originally, and having replaced both my diff's in my garage myself I would have told you this and saved you some time, but I didn't feel you had respected the VX family here, and quite frankly I didn't appreciate your calling out some of our most respected and loyal members, many here consider each other brothers, and you don't mess with someone's brother and make many friends. I hope you can redeem yourself now that you see how tight of a group we are here.
  1. Gear Ratio Combinations
    By bartmanS4 in forum VX Modifications...
    Last Post: 10/10/2014, 06:37 AM
  2. AR5 Tranny Ratio
    By bartmanS4 in forum VX Talk...
    Last Post: 03/05/2013, 04:44 PM
  3. 4400 RPM "LAG" in third gear 3rd Gear
    By Ikkesh in forum VX Troubleshooting...
    Last Post: 04/15/2009, 05:13 PM
  4. lower my VX
    By jacobus in forum VX Modifications...
    Last Post: 05/28/2006, 09:51 PM
  5. TeraFlex Lower Low?
    By Mile High EDGe in forum VX Troubleshooting...
    Last Post: 10/01/2004, 07:07 AM
