Mine also came off in the exact same spot. T4B is right; remove the heat blanket from the underside of the hood and you'll see the bolts and the windshield washers.
I took my insert off, laid it face down on a nice soft blanket so I wouldn't scratch it and scraped off the old epoxy from where the bolt came loose. I then used some J.B. Weld to re-attach the bolt back to the underside of the insert. It's been a couple of years now and the insert is still laying down where it should.
