Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Brakes need to be done
  1. #16
    Just a bit miffed...
    Took her in for a second opinion today and a completely different story. Guy said I have plenty of pad left and he wouldn't do anything until the end of summer in preparation for the winter here is CO.
    He said the rotors had some surface rust, but nothing to warrant replacing them.
    I guess whoever coined the phrase on the forum of "stealership" wasn't too far off in this case.
    Thanks for all of the helpful suggestions and encouragement.
    MSHardeman you can still come on over the we'll get the CO VXers together this summer.
  2. #17
    Jun 2007
    2001, Proton
    A new motto
    Dealership for parts, private mechanic for service.
  3. #18
  4. #19
    Mar 2010
    '01 Kaiser Gray VX#0867
    MSHardeman, I don't have enough experience with the VX, but every other vehicle I've owned, you would replace the front pads a few times before having to replace the rears. I can't imagine this is normal for a VX, I'm thinking a problem with the master cylinder? Do you notice poor braking?
    MileHigh, Also I can't attest to the brakes on a VX, but brakes in general, are usually a fairly easy DIY project, especially disc brakes. Some require special tools. If your handy, brakes will be easy for you. I usually just inspect and repack the bearings, it's a little overkill to replace them every time along with the pads. So justify the OEM pads with the money you saved on the bearings. The first and probably most noticeable upgrade would be SS brake lines to rid yourself of the sssqqquuuiiissshhhh..
    I'd like to hear from drilled/slotted rotor owners as well, I have heard that slotted rotors can build up ice in the slots, decreasing braking in the snow. Plus MileHigh, I'm guessing you make it up to the mountains, if the drilled rotors do help cool them, that will save the rotors from warping. Again, that is an upgrade, if you want to save $$, just have them turned, or if flat enough, just replace the pads.
    In my experience, brake shops are the worst place to take your car. They sell you cheap lifetime pads, but you end up paying them to replace those "free" lifetime pads every year. You or your regular trusted mechanic are the best ways to repair them. I almost never take it to the dealership as it is too expensive. I always pick repair shops that specialize in the type of car being fixed. Brakes are usually the first DIY project after changing the oil, so for this project, do it yourself and I think you'll be surprised at how easy and rewarding it is.
    '01 Kaiser SC'ed VX #0867
  5. #20
    Mar 2010
    I like the idea of a CO VX get together. Great trails start right from my house.
    You don't need to change pads until you're making scraping noises. Then you need to change them right away. Usually surface rusting of rotors gets scraped off by pads when you use them. I'm surprised in CO that you have any of that at all. Glad you got good advise and have a bit of time to decide how you want to take care of it.
  6. #21
    2000, Ebony, VX, 0370
    Thanked: 12
    RallyDude, I am surprised by the VX pad wear too, but it seems to be pretty common on all VX's. Actually my dad owns a Chevy Blazer Extreme and he is still on his original set of front brake pads at over 200k miles. He's replaced the rear pads a few times, but the front ones are still going strong.
    Is this some new phenomenon in the car industry?
  7. #22
    Here is what they look like...
  1. Brakes
    By tom4bren in forum VX Troubleshooting...
    Last Post: 05/16/2015, 07:41 PM
  2. No Brakes, Help
    By Scoobymlr in forum VX Troubleshooting...
    Last Post: 01/23/2012, 09:12 AM
  3. New brakes!
    By erland in forum VX Modifications...
    Last Post: 11/13/2009, 12:05 PM
  4. Me or the brakes?
    By cyronman in forum VX Talk...
    Last Post: 11/28/2006, 08:58 PM
  5. Brakes
    Last Post: 05/03/2006, 09:37 PM
