And I'm not talking about music.
My passenger window rocks front to back. Because of this it has some lean towards the front which lets the back edge out of the track.
What causes the rocking/looseness?
Jonathan
Jonathan
I think if you do a scearch under 'windows' you might find something about bending the track inside the door panel to aleviate this on.
I had the dealer do it under warranty...twice.
This is the best window fix posted by Paul Hines:
http://www.vehicross.info/forums/sho...&threadid=1180
This a common problem for many of us. Be VERY careful in using that window. Continued use of it can result in needing a replacement window regulator and even worse, a new window should the plastic tabs break off from the bottom of the glass.
Many of us have used a silicone spray on the window tracks on a regular basis to keep the design defect at bay.
Anita
2000 Ebony #263
AnitaProtich.com
