Results 1 to 7 of 7
Thread: Super winch hub review
    01, LineX tan/black, 1055
    I bought a set of superwinch hubs from Indy4x. They are very easy to put on. I tore one up on my last trip. When the CV joint broke, the remaining piece ended up getting shot out through the hub. No fault of the hub. I called superwinch, mailed in the broken piece, and they sent me two brand new ones!! Sweet, now I have a spare.
    Apr 2010
    Nice! The only issues I've heard from the Superwinch hubs are the allen head bolts in the "cap" stripping out and then having to be drilled out. I have the Aisins on mine. Always nice to have spare parts lol
    Oct 2003
    1995 Isuzu Trooper LS
    Some folks like having the hub as the "fuse" for their IFS, rather break the hub than something else...personally I like a stronger hub than the Superwinch.
    Apr 2007
    2001, Proton #1238
    That's what happened to the Superwinch hubs on my Mitsubishi Montero. Luckily you don't need all the bolts.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    I've actually sheared a bolt off in the aisins and had to EZ out it out. I then switched over to allen head capscrews which have a larger area on the head so if the internal hex gets rounded out, you can use visegrips to still remove them. They are also rated for more torque than what comes with the stock Aisins. It's a cheap upgrade I really recommend it, especially for anyone who wheels far from home at all. I'm also in agreement with Aisins being the best choice for a non-fuse system. When I researched my hubs, it was the general consensus that strengthwise aisins were the strongest. However, if you do break one, I seriously doubt aisin is going to have replacements sent out to you for free.......
    The problem with the Aisins, as we found out at the last Uwharrie meet, is they have a brass or bronze, internal wear part. If your aisin hub has any play in it, you need to get the rebuild kit from indy4x. As that starts wobbling, it allows play in the CV joint, and then, voila, broken CV shaft as it wobbles around under torque. The rebuild kit is like 70 bucks each. I will stick with my cheap superwinches Besides, my VX is a trailer queen
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    You could say the same things about any lockable hub. The only reason to go with them is what Marlin said about their great parts replacement policy. The bottom line though is that most hub designs have only 1 maybe two moving parts in them, so wear and tear is so low that you would almost never have to replace parts on them. I think in the wheeling community, Aisins are regarded as being pretty bulletproof. Warn and superwinch hubs aren't bad either, just more expensive initially. Most people start out wheeling the cheaper junkyard parts and only upgrade when stuff breaks.
  1. Winch
    By Vinnybin in forum VX Modifications...
    Last Post: 06/15/2014, 07:26 AM
  2. HID review
    By rx7tt95 in forum VX Modifications...
    Last Post: 07/02/2008, 03:07 PM
  3. Winch
    By Nerve_Gas in forum VX Modifications...
    Last Post: 04/15/2006, 09:49 PM
  4. Winch installed
    By rocket man in forum VX Modifications...
    Last Post: 05/23/2005, 11:48 AM
  5. Winch sale!
    Last Post: 01/12/2005, 01:02 PM
