My exhaust blew a hole through the mesh covered area just past the stainless steel or partial ceramic y pipe that converts to a single pipe. The are is directly under the driver seat.
I self repaired it by torching through the wicked ceramicy stainless steel end and cut through the other end which was normal steel. I put a solid peice of exhaust pipe but i can't get it to seal. The front pipe is not a true circle so i put some goopy sealant around it but it still farts around it. I basically destroyed the front piece by torching it- I think its a $1200.00 piece! Any suggestions out there to seal it better?
