Results 1 to 13 of 13
Thread: experienced wheel tech question
    Jun 2008
    2001,black, vehicross 1353
    how will 18x9 6x135/5.5 0(zero) offset 5.00'' backspacing fit on my vx?
    And how do they in compare to stock 18's? Will they offer a wider stance? weight concerns,etc?
    I'm looking at kmc rockstars matte black
    I have done alot of research but I could still use some advice.
    Milwaukee WI
    what size tire are you going to put on it? that will make the biggest fitament difference that wide a rim will probably not work with your factory tire, its just too wide. i would say at minimum you would need to go to a 255/55/18 if you want to stick close to factory
    from a different thread....
    factory wheels are as follows
    178mm wide. 127mm from inner lip to hub (protrusion into the wheel well) 51mm to outer lip of wheel
    on your 9 inch wheel it will go...
    0 offset - 114mm inner lip to hub... 114mm hub to outer lip
    +12 offset - 126mm inner lip to hub.. 102mm hub to outer lip
    +25 offset - 139mm inner lip to hub.. 89mm hub to outer lip
    +30 offset - 144mm inner lip to hub.. 84mm hub to outer lip
    your 5" backspacing is equal to the +12 offset... basically the wheel is going to stick out past the factory wheels by 1.5-2"
    if you go larger than stock with your tires, expect a good bit of trimming of the front and back of the front fenders.
    as far as balancing concerns, they are going to take more weight to balance, and some older balancers may have trouble with them, id suggest a place that does road force balancing to get the smoothest ride out of the new setup
    lastly, check out rickshaw's gallery, he is running 18x9 KMC wheels with a 5.71 backspacing, and they fit very well under his lifted VX with larger than stock tires
    just re-read your post.. a 9" wheel with 0 offset is different than a 9" wheel with a 5" backspacing.. not sure which you are looking at?
    TRIM TRIM TRIM, either way. etl pretty much sums that up.
    The amount depends on whether you have a lift or not and your tire size. I imagine you could get away with no trimming if you went with rubber band tires.... but do me a favor and save that look for the OTHERS.
    That low profile look with a 0 offset would be SILLEH!
    Feb 2010
    2001 VX 1320 -- Ebony
    Thanked: 19
    I think WormGod's wheels are 18x8.5" with 0 offset, right Gary?
    And, he has 285/60-18 tires that required trimming to fit.
    Look at his gallery to get an idea of appearance.
    Also,,,,use tirerack's tire search feature to see what tires fit with which wheels, what their width should be, and overall diameter.
    Stock diameter is about 29.75" from what I can tell. I think they're 38mm offset too.
    Wheel/tire combos I've seen recommended online usually land in the 18-20mm offset range. Past that's probably where you gotta start trimming -- especially if the diameter is bigger. Or,,,maybe their is more than one offset for that size.
    Edit: I just looked up KMC Rockstar. eBay had the 1st set of 18x9 with 6 x 5.5 pattern. That auction says the offset is 35mm (not 12mm). So, they match up fairly close to the stock config. If anywhere clearance on the inside would be in question (IMO).
    there are different offsets of the rockstar.. the 35mm is the one rickshaw has on his VX (5.71" backspacing)
    Jun 2008
    http://www.summitracing.com/parts/KMD-77589060300/
    This is the page- I just noticed the bore size hub hole might be too small. Arghh this is a PITA
    Wink
    Quote Originally Posted by djvx View Post
    You're making it harder than it is...use the search for every question that comes to mind...
    I just searched 108mm center bore &...
    http://www.vehicross.info/forums/sho...62&postcount=1
    I dunno if this'll help, but here it is...
    Aug 2008
    DJVX--- I highly recommend the KMC "XD-Series" RockStar in 20x8.5 (yes, 20" rims) with +10mm offset and 5.14" (35mm) backspacing with 108mm center bore opening on 6/5.5 bolt pattern (KMC Part #77528560310-Black). The 8.5" narrow rim, combined with the near factory 35mm backspacing will help minimize rubbing issues within the front wheel-well opening. Plus, the 20" rim will give your VX a very radical look for the Summer. These specific wheels are available at www.WestkyCustoms.com and sell for $239 each (ouch).
    Then, you can start dreaming about what 20" diameter tires you may want to fit on your VX for the Summer. Heck, it's only money.
    EDIT: Possible Tire Size Choices in 20" Rim Size:
    295/50R20 (31.6" O.D.) = this is a very rare size with only a small handful of choices. My personal favorite is the General - Grabber "UHP".
    285/50R20 (31.3" O.D.) = this size is nearly identical to the common 285/60R18 for VX's, except made for 20" rims. There are countless tires available in the very popular 285/50R20 size with many radical cool-looking V-Tread directional tread patterns. Visit: www.Tires-Easy.com
    Jun 2008
    thanks to everyone for their advice
    Only tire that looks good on 20's are 40inch+...just my opinion!
    only...five...inches...to...go...
    +1
    But I'll see your 40 and raise you 5.
  1. Replies: 31
    Last Post: 08/07/2014, 04:06 PM
  2. Experienced Engine rebuilders please comment.
    By Ebenezr in forum VX Talk...
    Last Post: 10/12/2011, 08:40 AM
  3. A little help? (Wheel question)
    By mattfett in forum VX Modifications...
    Last Post: 02/05/2008, 07:39 PM
  4. another wheel question
    By dmfk in forum VX Modifications...
    Last Post: 08/06/2007, 06:31 PM
  5. paid too much for speakers, tech question
    By Francesco Rizzo in forum VX Talk...
    Last Post: 07/14/2005, 02:21 AM
