Results 1 to 10 of 10
Thread: Fuel Smell
    Jul 2009
    2001 Silver 0737
    Fuel Smell
    I recently have had a strong smell of fuel when at idle, sitting at lights and starting.
    Also when idle turning in parking lots etc...my VX decides to shut off. I then have to put it in park and restart.
    Has anyone had this (these) issue (s) or have any suggestions on a fix before I take it somewhere?
    The help is much appreciated!
    look under the VX for signs of leaking, you will have to be quick though as gas evaporates quickly.
    i would be inclined to guess that its your fuel pressure regulator going bad. i had problems starting when mine went, on a warm start, i would get either a very very high idle or a very low idle and stalling. occasionally coming to a stop, especially on a hill, the vehicle would stall as well
    replacing my fuel filter and fuel pressure regulator eliminated these problems completely.
    01, LineX tan/black, 1055
    x2 on the FPR. Be careful which one you buy, the autozone one is junk, mine is already bad again after about 7K miles. When you do the job, there is a write up about it, there is one PITA bolt on the back of the bracket. Some replace it, I just left it off when I was done. Good luck, just use the search feature to find the thread....sure someone will do it for you soon
    2000, Ebony, VX, 0370
    Thanked: 12
    TADAAAA!!
    http://www.vehicross.info/forums/sho...or+replacement
    And since you're in Denver we could make a meet out of it (I'm over in the Aspen valley). Get a few of us together, replace an FPR....sounds like a party....WOHOO!!
    TADAAAA!!
    See I told ya, how is anyone supposed to learn to do anything for themselves around here?
    TADAAAA!!
    I'm in...we could repack wheel bearings as part of the parrtaaaa!
    And if we get enough of the right people there we could have one of every color for the photo shoot...
    You guys sure know how to party out there.... must be the high altitude/thin air. COme down to the east, we can do a tranny swap and timing belt tensioner replacement...now thats a party.
    Jul 2009
    2001 Silver 0737
    We'll have to see about a party!! I've also read some threads that suggest the intake manifold gasket could be the cause. Any thoughts or should I concentrate on the FPR?
    Thanks
    intake manifold gasket could possibly be contributing. Usually if its bad enough to cause symptoms, you see a check engine light. easy way to test is to spray carb cleaner or starter fluid in the area around the gaskets with the engine idling, if the rpms change, youve got a problem!
    Quote Originally Posted by daisyrae View Post
    Thanks
    I'll second Eric on this one. I don't think that a fuel smell would be associated with the manifold gasket. That would be a sucky leak where the FPR could be a spitty leak. I love using technical jargon (Learnt it from Brotha Dub).
  1. I smell dirt!
    By ahdoman in forum VX Modifications...
    Last Post: 04/15/2015, 10:35 PM
  2. gas smell
    By H3_VX in forum VX Troubleshooting...
    Last Post: 06/07/2013, 02:50 PM
  3. Help: How to Replace fuel lines going to the fuel rails.
    Last Post: 08/10/2012, 11:10 AM
  4. Hot Rim, Burning Smell
    Last Post: 12/23/2011, 12:35 PM
  5. Fuel Smell/Leak
    By Hotsauce in forum VX Troubleshooting...
    Last Post: 06/24/2002, 08:28 AM
