Originally Posted by
brainwashed
you wont be cutting anything for the rear speakers. you're gonna have to make a whole new bracket to hold them cause there isn't any holes for the rear speakers.
you mean like this
I used the new 6.5 inch mounting ring I.D. as a template to cut the old 4 inch mounting bracket so new 6.5 inch would fit. Had to use the new mounting bracket on top because it did not have the clearance for the magnet, but otherwise it worked fine.
