Results 1 to 8 of 8
Thread: question about idle
    Jul 2010
    99 sliver vehicross 0969
    question about idle
    sometimes when i start my VX the idle jumps up to 2 grand and doesn't come back down until i shut it off and let it sit for awhile why would it be doing that... (it doesn't do it every time i start it but every once and a while)
    Codyman checking out!!
    1999, Ebony, 0797
    That seems to be a really common problem, codyman. Mine went through that phase, too, and then self-corrected (so far). The idle was EVERYWHERE. High and low. Sometimes so low that it would basically turn over at startup and then immediately die. There are a lot of posts, and a variety of ideas for solutions, if you search the forum. I wouldn't say that there's a 100% guaranteed fix, though.
    Jul 2010
    thanks
    Aug 2007
    2000, Proton #0694
    Mine did exactly the same thing. I cleaned the EGR valve (free), replaced the TSP sensor ($20@autozone), reseated all my sensor plugs and vacuum hoses (free) - so far so good.
    Dec 2004
    '99 VX Astral Silver #0949
    My idle problems show up every summer when it's 90+ outside. about 10 days a year. It wants to die at the most embarrassing times, like slowing to a light, and you have to give it throttle to start, it can be hard to deal with.
    So far it "Auto corrects" as soon as it gets cooler. I've cleaned the sensor plug and used anti oxidents on the plugs. I've inspected the Idle air control and cleaned the MAF. one time I found the plastic air intake tube had loosened.
    I do get the low flow EGR CEL. off and on all year, and I'm due for new plugs.
    I'm dealing with 100F this week and it's just came back on Friday the 13th! I think I'll buy the plugs next, but I hate the idea of throwing money at it till it goes away, when it "Auto-Corrects"
    Sometimes I Wonder......
    Why Is That Frizbee Getting Bigger?
    Then It Hits Me
    Oct 2004
    99 Victory White Ironman 0685
    Mine just started doing this...reving to high...It has been over 100 for 22 days in a row
    Chi Dog...Dog is my Co-pilot
    Onward thru the fog
    Mine has done it for years on fresh starts. Runs fine, then after about 20-30 secs of running, it revs to about 2200 then drops to normal and stays there. Never been able to trouble shoot it though I have been able to get it to at least only THIS issue. Used to rev, sputter, and cut out.
    Sep 2009
    2001, White, Ironman, 0569
    Happened to me too. Idle hit 1800 and kept rising, had to shut car down to keep from rear ending in the winter. Turned out to be my Power Steering Pressure Regulator. Have that diag'd as a possible solution.
  1. Fast idle, low idle, (stalling) temp gauge all over the place.
    Last Post: 11/07/2016, 08:48 PM
  2. Another Idle issue
    By housertl in forum VX Troubleshooting...
    Last Post: 09/27/2011, 06:29 PM
  3. another idle question??
    By gabilangabby in forum VX Troubleshooting...
    Last Post: 07/23/2007, 06:25 PM
  4. High idle question
    Last Post: 01/18/2007, 05:14 PM
  5. idle
    By cascabel3 in forum VX Troubleshooting...
    Last Post: 12/17/2004, 08:30 AM
