Results 1 to 10 of 10
Thread: Where can I buy camber shim kit?
    '99 Blk 0089
    I need this camber shim kit to have a perfect alignment. Please let me know where you guys/gals got yours.
    Thanks much!
    Call a few alignment shops that are local to you.
    97 Jap Import, Black BEAST
    Made mine with some sheet steel and an angle grinder
    Hunter provided the ones used on mine.. So any shop with a hunter alignment rack should have them or be able to order them
    '99 Blk 0089
    I originally got the alignment done with Brake Check, lifetime deal, so after getting new shoes from Lambs with a free alignment check, they notified me that my (camber) alignment is way out of spec and would need the shim kit.
    Went back to Brake Check and they agreed, however, they said they couldn't source the camber shim kit from anywhere. If this so called shim kit should be available at any alignment shop, then perhaps this Brake Check shop must be incompetent
    Is this camber shim kit a universal shim or specific to the vehicross?
    Quote Originally Posted by JULIAN911 View Post
    Reading this thread may be helpful... Pics & everything...
    http://www.vehicross.info/forums/sho...er+shim&page=2
    99 Silver VX
    GM starter shims for a small block....they work...look in the "help" section of your local auto parts store....
    2000, Ebony, VX, 0370
    Thanked: 12
    I haven't done this so hopefully someone who has will chime in, but doesn't doing the "ball joint flip" help out with this issue?
    Not so much, maybe a little...
    What it DOES do, is give a bit more down travel, (droop) especially in conjunction with low-pro droop snubbers. (bump stops)
    2001, Ebony Black, 1153
    That was my understanding as well as giving some slight increase in down travel. I have the t-bars almost maxed out, with the ball joint flip and the VX always gets a good lifetime alignment from Firestone, I don't know what to tell you sorry
  1. Negative Camber
    Last Post: 03/20/2011, 08:32 PM
  2. brake pad shim grease
    By SlowPro48 in forum VX Talk...
    Last Post: 01/14/2010, 12:04 PM
  3. Shim Tool?
    By logman in forum VX Talk...
    Last Post: 12/24/2008, 07:13 PM
  4. How to adjust camber?
    By marcosv6 in forum VX Troubleshooting...
    Last Post: 04/25/2006, 09:12 PM
  5. Camber Questions
    By wrestler11 in forum VX Modifications...
    Last Post: 11/12/2005, 10:27 AM
