Results 1 to 15 of 20
Thread: 99 Dying - CHECK YOUR OIL
    Aug 2010
    1999 Black
    Unhappy 99 Dying - CHECK YOUR OIL
    Well...Guess I'm just looking for some advice. After being a dilligent oil checker and proud VX owner for 4 years, I laspsed. Too many extraneous things going on (divorce, surguries, last parent about to pass, forclosure).
    With all my drama, I lapsed in checking my oil (although it was not burning alot recently). It got a bottom end knock last Tues. After checking, it needed 3.5 qts of oil. I then changed it and there were shavings in it. It'll need a new engine shortly. At least for the immediate future, I do not have the 3-6K it'll take to do that.
    It was my remaining "pride and joy" possesion. I'd really love to save it and I may still try (even if i have to garage it for awhile to come up w the $). But with everything else, it might have to go.
    Guess I'm just checking on my options. Any budget swaps doable?
    Any ideas on a price for selling it as is? Any thoughts on what parting it might bring?
    p.s. - CHECK YOUR #$*&^ OIL
    Aug 2010
    1993 trooper rs
    IDK how much of a budget your on, but after the core you can get a complete long block for $2,286 hear
    http://www.rockauto.com/catalog/x,ca...,parttype,5240
    Aug 2010
    1999 Black
    I'm still trying to figure out how to make it work. virtually no $ right now, but could come up with 3k in 3-4 months...asumming they are not any new surpises in my life
    Aug 2010
    1993 trooper rs
    When I worked for Auto Zone, I remember seeing this stuff called No Knock or something like that and it was supposed to try and keep your motor on it's last leg for as long as possible. I just tried to google it and couldn't find anything on it but it's in a gray bottle with black lettering. Sorry I can't be more help to you.
    Jun 2008
    2001,black, vehicross 1353
    I'm going to make a note of that link/price
    Quote Originally Posted by surf-life View Post
    thanks for the link
    Milwaukee WI
    Jan 2008
    1999 Astral Silver 0481
    Lightbulb
    Quote Originally Posted by onetraxmine View Post
    Hello.
    Get in touch with "ianiroman" he did a swap with an 2002 isuzu axiom engine long block that doesn't burn any oil.
    Long block can be found around $ 2000-2500 over the internet and you can use the short block of the VX engine with no problems at all.
    Long block must be one produced before march 2002 with the 8th digit being an "X".
    Anyways get in touch with iamironman for more precise info.
    Dakar was just the begining.
    Aug 2007
    2000, Proton #0694
    All i can say is hang in there and don't give up. I had my motor blow up on me too because of oil related issues. It took me six months of saving a couple hundred here and a couple hundred there until I saved the money to get a replacement motor. All while I was still making car payments and struggling with no vehicle. I wasn't about to give up hope. Now my baby is back with me and running great. I literally check my oil daily now.
    Jun 2007
    2001, Proton
    I have found
    if you pay attention to the sound of the motor you can tell when it needs oil. It gets a little louder and whinier
    Try maybe some "Motor Honey" and run it as long as you can if its all you have to drive.
    Sorry to hear.
    Aug 2010
    1999 Black
    Thanks for all the condolencses. Still not sure what Im gonna do, but I'll keep y'all informed if i swap moptors, sell or part.
    Aug 2005
    1999, silver, 0887
    YOu could disassemble and maybe line bore the block and go for oversized main bearings if the crank can be turned. Worth checking out.
    Aug 2010
    1999 Black
    it is actually still running, but with a start up knock and a tick from the bottom end, it's not viable for anything other than moving in and out of the garage
    1999,silver,vehicross,1891
    my 1999 burns oil, it doesn't foul it, it just vanishs; I add a quart by routine, every 2 to 3 tanks of gas, problebly more than that, it just consumes it; then every 1500 to 2000 miles, I when it's low I just dump it, and fill it up, all the way, plus an extra half quart, I also bought a case of CERTECH, and use that every fill. Its my understanding that the problem is the oil ring, lacking adequate number of drain back holes. Anyone know if thats true?
    Jan 2006
    99, black,
    Cowboy.. I have the same frickin' problem.. Gotta watch that oil level.. I wind of going through a quart every 1k miles. Using a thicker viscosity doesn't seem to help either..
    And it is interesting that my vehicle still passes emissions... ;0)
    But I'd be careful about overfilling though..
    Dio
  1. Starter dying?
    By volume311 in forum VX Troubleshooting...
    Last Post: 06/01/2014, 05:24 PM
  2. Trans is dying...
    By HeckaTrebeka in forum VX Troubleshooting...
    Last Post: 05/22/2013, 09:03 AM
  3. Help - Is my CD changer dying?
    By TexVeX in forum VX Troubleshooting...
    Last Post: 10/25/2007, 05:49 AM
  4. dying starter
    By doubleadesign in forum VX Troubleshooting...
    Last Post: 10/14/2004, 11:11 PM
  5. windows dying on me
    By dragonfly22design in forum VX Troubleshooting...
    Last Post: 03/03/2004, 02:43 PM
