Hey guys,
Ive been over here in Hawaii working on the property we bought a few years ago. The Vehicross has been great for getting me thru the pukas and brush.
Ive used it to pull some nasty roots from across the driveway already. I noticed
the other day while leaving it was slipping in reverse.
I did a fluid swap before I left Seattle and filled it to the proper amount of fluid. The fluid that came out was used but smelt/looked/felt fine.
Since I noticed it slipping, I again swapped the fluid and the transfer case thinking that could be the issue. It was still slipping so I added a bottle of Lucas to the tranny with nothing.
I plan on using the tranny till it goes so I have some time to get a new one.
Ive already started asking local places for one but nothing positive yet. Its Hawaii you know, theyll get back to me after the look thru the yard.
This area is hard pressed for work and I heard of a really good transmission guy.
I was thinking maybe I can just replace or fix whats Wrong with the Reverse gear for a couple hundred bucks cash???
Can I get just a reverse band or gear or spring?
Can you put that in from the bottom?
Please I know one of you guys has the answers, anything would be great.
Thanks guys.
Sean
