this seemed to be the most logical place to mount one
this is a mock up for test reasons, I took a spring
tack welded a washer to the bottom, then found the mounting
spot. I then drilled a 1/8" hole in the body panel and sctewed
the unit onto the body. done.
1 thing I will say, Im going to add a longer, maybe even a little
stronger spring then the one pictured.
