Results 1 to 9 of 9
Thread: Active Braking System (ABS)
    Dec 2003
    Former Owner 0216
    Yes, I know it's anti-lock and when it's being use in a hard braking situation the pedal pulses. However, during normal braking mine does pulse, but not as actively as during the other time.
    Any thoughts??
    Darrin
    2000 FIREFOX 0009
    Could be a warped rotor
    Dec 2003
    Former Owner 0216
    I did have them turned about 1.5 years ago and I guess they could be worn again. Hafta check...... THANKS
    You know every mechanic I've ever been to has recommended against turning rotors, with several of them refusing to do it at all for safety reasons. Obviously they have a vested financial stake in replacing them, but anybody agree/disagree with that opinion?
    Jul 2009
    It does seem to be the considered opinion of just about every mechanic out there; replace, do not refinish the rotors. Kinda sounds like a profit and liability issue!
    Vixer Fixer
    Feb 2010
    1999 Ironman,#1-1767, #2-1326
    some places may not have the lathe anymore also.
    Feb 2009
    1999,silver, 1516
    My brother is an ASE certified Ford mechanic and they have no problems turning rotors. The thinner the rotor, the easier they are to warp though. Also, they have to still be within spec for the application (obviously). They can't file off so much material that the rotors are thinner than accepted for that vehicle.
    My experience is that a lot of tire shops etc that mount wheels with impact wrenches are the reason rotors warp. Or by tightening down one lug all the way to spec without working them all down in a criss-cross pattern.
    2001, Dragon Green, 1342
    Think the fronts need to be just to true them up with the hub
    Sep 2010
    2001 kaizer vx
    Agreed. true. myself cert canadian mechanic. But, sometimes cheaper for cust to get new rotors then lathe the old ones.
  1. Bad braking coming to a stop, help please??
    By VX4EJR in forum VX Troubleshooting...
    Last Post: 06/17/2016, 04:21 PM
  2. Turn signal on when braking??
    Last Post: 11/19/2012, 07:08 AM
  3. braking problem
    Last Post: 01/19/2009, 09:57 AM
  4. Military, active, reserve,etc
    By IndianaVX in forum VX Talk...
    Last Post: 04/28/2007, 10:27 PM
  5. Clicking when braking
    By spitfire5454 in forum VX Talk...
    Last Post: 09/30/2004, 02:09 PM
