Results 1 to 13 of 13
Thread: My cargo area light
    My cargo area light
    Picked this up at Lowes. It rotates up/down, can be removed (hand held), or turned lenghtwise. It has 4 very bright LEDs and is made of brushed aluminum. $13 and 5 minutes to install...
    (sorry for the phone pics...all my camera batteries were dead)
    Oct 2009
    99 Astral Silver
    Wired in or batteries?
    01, LineX tan/black, 1055
    Quote Originally Posted by RabidPony View Post
    At only 5 min install and removable function....batteries
    Oct 2009
    99 Astral Silver
    Good point. Didn't see the 5 min part. Looks really good though.
    Does it come in black?
    No, but spray paint does!
    The base on mine was actually white...some lite sanding and a bit of flat black and it is no longer white.
    And to the ? above...battery powered. Should last a long time though from past experience with LED's and batteries.
    Cool
    Ah thinks its P-U-R-D-Y......
    Mar 2010
    '01 Kaiser Gray VX#0867
    I might have to copy you on this one. I could see it either console, near the rear view or under-hood mounted as well. Some members have mounted a wind-up dome light from a Suburban. Personally, with as bright as the new LED's are, and they are so efficient, I'd rather go with wireless, and I like the look of this. Most flashlights used to be battery hogs, were not that bright and worked finicky. Now there is great, bright, battery efficient LED's that are reasonably priced as well. It's a cool little lightbar, and looks like a nice fixture, rather than just a flashlight, plus it is aim-able. Nice find.
    '01 Kaiser SC'ed VX #0867
    Quote Originally Posted by RallyDude View Post
    I wonder how heat tolerant it would be? It is a plastic housing after all. Maybe if it was mounted on one side or the other of the engine compartment it would be okay? But then how is it better than a mini-mag lite kept in your glove box?
    Mar 2010
    Actually, he said it was made of brushed aluminum. Plus it has a mount that either allows it to be aimed, or it can be removed. I'm guessing with the multiple LED's, that it is probably brighter than a mini-mag. Just a cool little cheap mod, a nice finishing touch.
    I thought the mount looked like plastic... but maybe it's all aluminum. In any event, nice mod, definitely not dogging it at all, just trying to think through the applications.
    Base/mount is plastic...the “wand“ is metal with plastic end pieces. Not sure it would do well under the hood.
    Tested it out last night after the sun went down...it lights the back up very nicely. And as an added bonus if you turn it to the front it makes a great reading/map light for the rear passangers/navigators!
  1. bed lined cargo area
    By orion in forum VX Modifications...
    Last Post: 05/09/2011, 08:27 PM
  2. Cargo Area....
    By JAMAS in forum VX Modifications...
    Last Post: 05/02/2011, 02:39 PM
  3. Rear cargo area dome light
    By Mile High VX in forum VX Modifications...
    Last Post: 02/25/2011, 06:43 PM
  4. Cargo area dimensions?
    By RickOKC in forum VX Talk...
    Last Post: 07/08/2010, 12:17 PM
  5. rear area cargo light.
    By don moore in forum VX Modifications...
    Last Post: 11/27/2009, 09:18 PM
