Results 1 to 15 of 16
Thread: U-joint replace how to
    01, LineX tan/black, 1055
    Anyone have a U-joint replacement how to. Just ordered em for the VX and the Trooper RS (same parts). This looks fairly simple, but I have never messed with em before...I tried the planet, didn't see anything.
    2001, Dragon Green, 1342
    Here you go Chris.
    http://autorepair.about.com/cs/doity.../aa102602a.htm
    It's pretty straightforward, but the first time can be a pain. You have a autoshop on base don't you? Go there, plenty of experts around to help out
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    They're easier than you think. I don't know if that guide mentioned it or not, but you must install the new ones in the same orientation that the old ones were in. What I mean is that the shaft must line up with the yokes the same way it came out on both ends or you will get a nasty driveline vibration. As with everything mechanical it's a good idea to take pics before you take anything apart and mark indexing lines on what goes where. It is especially true of this. They can be surprisingly easy to screw up. Seen it happen way too often.
    Thanks guys, I know about match marking anything that spins. Its strange that my auto experience is relatively new, yet I have been working on multimillion dollar 8MW turbine generators for 13 years. I have set fire to equipment that cost more than two brand new VXs put together...yet I hesitate to do something simple like U joints w/o instructions? LOL. Maybe I will do a VX specific write up with pics. We shall see. I don't even know if they need new ujoints, but at 13 bucks a pop, why not?
    marlin, i got a printout through my works shop manual database that gives a step by step with specs. i dont have a scanner, but i can drop it in the mail for you if it would be helpful
    Eric,
    I can scan it & post it to the DL section.
    2001, Ebony Black, 1153
    The place that did mine a month ago did a high speed balance on the driveshaft after they replaced the U-Joints, I don't know if this is necessary but it sounded like a good idea to me, they replaced and slightly repositioned the balancing weights to get it right.
    Yes, always worth it. When I do U-joints, I change them take to them for the balance to save a few bucks labor
    ok tom, print-outs are on their way.. 7 pages
    Thanks, I am still on the road, I was gonna shoot you a PM, but if it gets scanned and added to our database, all the better.
    Sep 2010
    1999 silver vx 0250
    marlin,
    where did you get the u joints for 13 bucks?every where i looked they were 30 or more.
    Quote Originally Posted by vxfocus View Post
    marlin,
    http://www.autozone.com/autozone/par...mString=search
    Sep 2010
    1999 silver vx 0250
    thanx are 2001 u joints the same for 99 vx?
    I dont see why not, but just go to the autozone website and put in a search for a 99, my wifes 93 Trooper RS took the exact same parts as well.
    Jul 2010
    1999,silver,VX,0118 & 1144
    it comes up up not available...
  1. How to replace lower ball joint?????
    By LittleBeast in forum VX Troubleshooting...
    Last Post: 06/27/2014, 05:11 AM
  2. Why did my CV joint disappear?
    Last Post: 03/15/2010, 11:46 AM
  3. U Joint problem
    By tngerman2000 in forum VX Troubleshooting...
    Last Post: 08/17/2006, 09:10 AM
  4. The perils of a U-Joint
    Last Post: 05/11/2006, 11:35 AM
  5. Ball Joint?
    By V12BMW in forum VX Talk...
    Last Post: 11/13/2004, 08:42 AM
