Results 1 to 3 of 3
Thread: Replacing dead brake light bulb
    Discovered passenger side brake light not working this morning. Found two screws on outside of assembly which I removed but unable to find where else it is attached to change out bulb. What's the trick?
    Scott
    there are two presure pins that hold the light in once the screws are removed. pull the entire assembly gently away from the vehicle (straight back, like you are driving and your tail lights fell out).
    then it is the middle bulb in the housing, 1/4 turn will remove the socket
    Thank You!!!
  1. Replacing damaged brake hose
    By soggybottomboyz in forum VX Troubleshooting...
    Last Post: 11/17/2014, 07:35 AM
  2. Help with replacing Brake Lines
    By frankd14321 in forum VX Troubleshooting...
    Last Post: 12/10/2012, 07:41 AM
  3. Dead short in Rear Light/Instrument light
    By Damien Jones in forum VX Troubleshooting...
    Last Post: 07/16/2006, 07:49 PM
  4. LED vs. Bulb... horn light test.
    By Dallas4u in forum VX Modifications...
    Last Post: 09/13/2003, 07:45 AM
