The insulation blanket under my hood is looking discolored and an area over the battery is deteriorated due to acid I suppose. Has anyone come up with a good solution without spending the $185 I see they are asking,if indeed it is available?
I think the consensus is that the insulation is not needed. There should be absolutely no issues if you just remove it.
or
If you're not worried about 'pretty', I've 'fixed' several on other cars in the past with pretty good results. Home Depot or Lowes should carry aluminum tape (for duct work) that's easy to apply & holds up well. This is probably the only application where Duct Tape (the fiber kind) can't fix it. That stuff will break down & fall apart in the hot environment of the engine bay.
Here's a thread where it's discussed:
http://www.vehicross.info/forums/sho...engine+blanket
I think the only real advantage to having the liner was noise and vibration damping. My battery exploded a while back and it turned it into pudding and I haven't used it since. Without it, it's kinda nice hearing more of the S/C whine anyways.![]()
Dynamit would work well for heat and noise with no issues of stuff falling into the bay
Carter Pewterschmidt
Dynamat and others make mats specifically for high-heat areas such as under hood...
Thanks for the thoughts guys... I'm not up on the Dynamat stuff. I'll look into it. Heat wise I suppose a guy should expect what under hood maybe 250 degrees?
John, did you get the photo's I sent you?
Yes John, I did. Thanks. You said I could post them with my questions but you were not fully aware of my ineptitude on this machine.I really do have some redeeming qualities though....honest!
With everyones help I found the solution I think. 1/3 the cost of the Isuzu part if it was available.
http://www.b-quiet.com/hliner.html
On many cars and trucks, the insert is used for noise dampening yes, but I think more so for blocking heat that actually causes paint discoloration on the top of the hood. You could easily use some lizardskin to block heat the same way and block noise as well. Obviously it won't fall off either. I have also seen sheets of aluminized insulation similar to what we have available from most auto parts stores. It would be attached in the same manner as our stock insulation.
