Still no relief for the VX idle problems . I have intake gaskets on order .
Yay! my first engine oil leak today . Where is it coming from ? .... I don't know .
Chechk the EGR valve. See if the tube is on tight at the EGR valve base, itself. Use a short handle 22mm to get it tight. Hope this helps, but you cannot go wrong with new common chamber gaskets, either.
Long over-due update . I replaced the battery terminals, and the idle problems have mostly disappeared .
when its pulsating ! i aint idle
