Question
Would synthetic oil cloud up if water, or coolant
wAs mixing with it?
I am STILL dealing with the overheating issue. Thought
I had it whipped when I replaced the thermostat, and
New intake gaskets, then a couple of weeks later it
Started to smoke at start up, but quickly quit smoking
After it warmed up. Well, Monday night, it wouldn't stop
Smoking so I took the intake off, and found it FULL of
Coolant. So I replaced gaskets again, got it all
Together again fird it up, and it smoked more than before,
Killed an o2 sensor (bank 2 sensor 1).
The oil was changed just a couple of weeks ago, and looks
Like it should.......and is not milky AT ALL.
Now I'm thinking heAd gasket, but would have thought the oil
Would be milky.
If it's not head gasket, where, and how would all that coolant
Fill the intake?
Any suggestions
Thanks in advance
