Results 1 to 15 of 22
Thread: 'Help a VX Noob' Foundation
    Question 'Help a VX Noob' Foundation
    Hello All,
    I'm thinking about buying a VX... I've been lurking here for a while, reading through the threads, building up my 'knowledge base'.
    What a great bunch of people!!
    Anyway, I'm a little concerned about quality. With all the posts about binding windows, water leaks, banging transmissions, crappy dealers, etc. - I'm wondering what I might be getting myself in to. I would drive this car every day, and take it off-road occasionally.
    So, if you had it to do over again, would you buy? Should I buy (in your opinion)?
    Thanks, Rick
    Aug 2003
    1999 White Ironman #1564
    I have a 99 Ironman. It has 101,000 miles on it now. The only complaint I have it that it uses a bit of oil. 1.5 - 2 Qt / 3000 miles. The dealer looked it over multiple times and stated that the consumption was within spec. Never have had a problem with it, other then a squeeky hood (thanks to whoever recommended raising the little rubber things...that fixed it) and the headlight seal problem (fixed with a little silicone stuff). I drive it everyday...alot. I hope it lasts a couple more hundred thousand miles.
    Thanked: 7
    My answer would be "absolutely, yes." There is nothing like a VX on the road. But I would make sure of a few things:
    1) Make sure you have reputable dealer/service department or independent repair shop within an acceptable driving distance. IMHO, this is MOST important when considering buying a VX.
    2) Since only used VX's are around now, a complete diagnostic look-over of the VX is essential. If you do find an VX for sale, if possible enlist the help of VX owners on this forum who live in the area to take a look at it with you. I dont think there is anyone who could boast knowing more about a VX than those who own a VX and follow this forum.
    Best wishes with your decision!
    ;Dr;
    Anita
    2000 Ebony #263
    AnitaProtich.com
    1999, ASTRAL
    Problems... What problems???
    The windows bind for the same reason an engine will eventually sieze...LACK OF LUBRICATION. As for the weather striping around the headlights, be prepared to glue it. Truthfully, the issues mentioned are of a service nature, NOT defects
    I have never owned a vehicle that was perfect, but with the minor serviceable issues of the VX it is sure close Remember the VX is not for everybody, it has a very stiff sports car ride, and if you have kids/back seat passengers older/bigger than 10 year olds consider it a 2 seater. Emphasis on SPORT off roadster of sorts
    NAVIGATOR
    Oct 2002
    Actually when I fixed my window (per instructions posted here) I watched the window go up and down a few times with the door panel off. The cause of the bind is due to incorrect placement of the lift point. It needs to be moved directly under the center of mass of the glass. It isn't. If I remember correctly, it is aft of the center so when the window moves up, the glass pivots (dives forward and down) as it travels upward... the further it goes the more resistance it meets from the rubber seals. Spreading the window track slightly with a pair of channel lock pliers solved the problem. Less friction between the glass and seal. The glass still pivot but the amount of resistance is less so no binding. My drivers side window actually moves a little quicker than my passenger side now (didn't need fixing)... just a little. Before, the passenger side would be completely up while the driver side is less than 1/4 way up.
    I've had mine for a year now. My dealer, the only one in Portland now, is OK. I find that as long as I don't go in for reasons other than general maintenace, things go very smoothly. Anything beyond that, I try to take care of myself... and the info archived here is very helpful for that.
    Other problems fellow members have mentioned above are all common problems... basically resulting from lack of research and attention to detail in the production engineering phase... which is to be expected on any limited production vehicle. All are minor problems and most of them can fixed on your own within a few minutes. The window fix took 20 minutes at the most. I haven't had any water leaks yet, knock on wood, but I think that is more common among the '99 and some '00.
    One other thing people have had problems with is the hood inserts developing hairline cracks. While they have met some varying degrees of resistance from the dealer, I think most of them eventually got the dealer to replace it under warranty. The consensus on the cause is overtightening of the mounting fasteners. Something to keep in mind and to relay to the dealer if you ever find yourself at the dealer for this issue.
    Good luck with your search. www.autotrader.com and ebay motors are good places to look.
    Nov 2002
    As you can see the VX is all-in-all a great vehicle. As mentioned previously, some quirks are to be a expected from a limited production vehicle that's hand-built. I've owned four Isuzu vehicles since the mid-'80's, three of which have been Troopers, and have put well over 150,000 miles on each with little trouble if any at all. The VX comes from that same lineage and is essentially constructed of proven off-the-shelf components. I've had mine since new in November and the only problem experienced is the number 3 CD slot won't accept a disc. Big whoop, it's the same changer in all Isuzu products and has nothing to do with the quality of the VX.
    Just be sure to shop around, get a FULL CarFax report and use due diligence and common sense as you would with any vehicle purchase. Other than that I don't think you'll find a better support group than the folks here!
    I'd have to say that I would buy it again. Price / performance ratio is good compared to what else is out there. A unique , limited availability, underdog. Ignore any visual comparisons to RAV-4's or Santa Fe's . This is a full- framed TRUCK. I haven't had any major problems and the minor ones have been resolved to my satisfaction, by the dealer. Several members here do have problems with service on their VX's . So do have it inspected by a local member if possible. Try to locate a competent dealer or other service facility near you due to the fact that many dealer service personel are as unfamiliar with this limited production model as is the general public.
    One major thing to note: The rear vision is difficult. If you've ever driven a panel -van or other truck where you use the side view mirrors to back-up, it won't be a problem. Otherwise convex mirrors, van-eyes or rear camera setups can help.
    2000GREENVX0575
    best darn motor on the road
    Buy Buy Buy
    This is the best motor I've ever had, and tops the DISCOVERY and the RANGEROVER AND THE MITSUBISHI,all of which ,although stating the best 4x4 by far etc, never quite lived up to their expectations.
    With the Rover and the Discovery it was the maintenance or lack of it on behalf of the dealers.
    Put aside small things like the window and you are looking at a reliable manouverable and agile machine,not an urban attack vechile.
    Join the VX family
    Never pack a gob****e there's always one waiting for you when you get there.
    2002, Grey, Axiom, 7578
    Do not buy a VX!!! We do not want anyone else in on our little secret... If everyone wants one of these amazing vehicles, the price will go up and I will have a hard time buying a second and third VX for myself ;O)
    By the way, I now have over 58K miles on the speedo and this vehicle has never been to a dealership. I have done all the preventative maintenance at other auto service shops. I had a little problem with the window binding, but after using the silicone spray, I haven't had a problem since. I also broke an internal plastic piece on the driver side door. But I just ordered the part and installed it myself. I love Isuzu vehicles - I have owned one since 1988.
    Brent
    Smile Thanks!
    I said it once and I'll say it again - what a great bunch of folks!
    I know you're all biased, but THANKS for all of your feedback - you've helped me address my concerns. I think I can handle the small issues that may arise - and go forward with my desire for something unique.
    I'll be replacing my WRX, which used to be unique. But now they're a dime-a-dozen (at least here in the northwest). I wish I could afford both!
    I'm now on the hunt for a black 2001 - I've got a couple on the line...
    BTW, what really sent me over the edge on a VX were the pictures of of Daver's and Wormgod's black beauties... Here's one:
    SWEET!
    Heck yes I'd do it again!!!
    Andy
    Its the thrill of the chase
    '99 silver (#1897)
    Local "Auto Trader" mag has one (black) for $18K with 10.5K miles
    ________
    Vaporizer Wholesaler
    Oct 2002
    Andy
    Wonder if Isuzu is listening... too bad if they're not.
    Thanked: 7
    Only 10.5K miles??
    Yikes, check that one out!!!!! ;Dr;
    Only 10.5K miles??
    How does .9K miles sound!?!
  1. Possible Purchase??? Help me out, I'm a noob..
    Last Post: 10/25/2014, 03:28 PM
  2. I'm also a noob looking for a VX
    By simonsayz1 in forum VX Talk...
    Last Post: 10/20/2014, 07:24 AM
  3. Rust on bumper...noob needs help!
    By KING FROG in forum VX Troubleshooting...
    Last Post: 07/14/2009, 01:59 AM
  4. noob question
    By boostedte37 in forum VX Talk...
    Last Post: 01/20/2007, 07:40 PM
  5. Proud new owner with noob questions!
    Last Post: 05/09/2006, 09:05 AM
