Results 1 to 5 of 5
Thread: Upper A arm ????? Help needed
    Question Upper A arm ????? Help needed
    Hopefully someone who has had their front end apart can give me a quick answer to this question as I am in the middle of replacing my ball joints...
    should the upper A arm have side to side play in it? or are my bushings bad? With it disconnected from the ball joint I can move it back and forth about 1 inch...does this sound normal?
    Jun 2010
    1999, Silver, VX, 0401
    Sounds like your bushings are bad. When I had mine apart it would move up and down but not side to side.
    Cool...thank you!
    01, LineX tan/black, 1055
    x2
    Yep...drivers side is nice and tight, pass. side not so much. Will be calling Merlin in the morning.
  1. Greaseable upper ball joints vs sealed?
    Last Post: 05/22/2014, 04:59 PM
  2. Ball Joints - Upper and Lower
    By lasturbo in forum VX Troubleshooting...
    Last Post: 11/27/2012, 04:54 PM
  3. Help needed
    By Grok in forum VX Talk...
    Last Post: 01/10/2011, 12:42 PM
  4. Upper control arm bushings are a PITA!!!!!!
    Last Post: 12/15/2010, 12:21 PM
  5. Upper Ball Joint Problems
    By crotchrocket in forum VX Troubleshooting...
    Last Post: 10/06/2009, 03:53 PM
