Double post - so deleted.
I have had metal hub centric rings made for me in the past to specific wheels.
Agreed ^
The only problem that larger than our 100mm bore presents is in the aligning process when you first are trying to get the first few lugs going on straight.
I had custom rims cut to my specs for the VX and I thought it was 108mm, but when I put them on I measured and found out that was WAY off, so it just means that it is harder for me to line up the first couple of lugs when reinstalling. Centerbore doesn't matter as long as the lug pattern is the same and the hubs fit, the lugs when tightened correctly (each one a little at a time) will align everything perfectly every time.
Well Little Beast is proof that the mis-information about our center bore being 108mm did affect someone. Granted the rims still worked out afterall. I think someone should change the tech info on the "Post of All Rims thread" to 100mm. With a note that 108mm is a proven workable sizing option.
My point is this:
If your rim is centered by the hub AND by the lugs the two processes will work against each other unless VERY tight tolerences are held during manufacture.
If you were to purchase a true hub centric rim (assuming that our hub was designed for it, which I doubt) and installed it using lug nuts that are designed to also center the rim. The conical nuts would try to adjust what the hub has already aligned. One of two things will happen (prolly #2)
1. The hub or the centerbore of the rim will deform to allow the rim to center somewhere between where the hub had it & where the lugs want to put it. Congratulations, you've just violated the hub centric design that you wanted so badly.
2. The lug nuts won't tighten properly and will eventually vibrate loose. Nobody wins in that situation.
Like I said in an earlier post, in all likelihood our factory rims are lug centric & just happen to have a fairly tight fit to the hub but are not hub centric.
