Originally Posted by
Riff Raff
A major problem our VX's have is the very tightly cramped confines of the front wheel-wells. The best we can do is take steps that help minimize rubbing and clearance issues when installing larger size tires. The strict use of OEM rims (whether 16's or 18's) greatly help in this regard to install larger tires with minimal fitment problems.
I don't think our front wheel well is as small as you think. My wife's RS is basically the same truck, minus all the plastic hoo hah that we have. There is a TON of room in there. I did no trimming for her 33s and I would bet I can get 35s in there with maybe a bit of trimming. Big swede got his in there and he has the wide stance mod as well as some decent offset. I think on the OEM 16" VX wheels I have, those 35s would fit with no trimming. You can see how much room there is on the RS, we just have the cladding that makes everything look smaller than it really is.
If you remove that plastic splash guard, cut the inside part of the cladding where it wraps inside the rear of the front wheel well and pound/cut out the metal that is just there to give the cladding something to attach to, trim the front corners off the cladding, I think 35s would be no problem. My rim is very close to factory offset, at your recommendation a few years ago. you were 100% correct in that idea, but as I have said, I am running a 34x11.5 and I am close to stock front height, I have no rubbing, full turn stop to stop with no adjustments and I have had it full flex even with the IFS kit. It would certainly require some rear lift to allow for full flex.
If you look in this pic, I am on the front low profile stops I upgraded to, and the wheel has plenty of room, once you remove the splash shield. I just rubber coated the inside of the fender with 3 coats or so, to prevent any chips from causing rust later down the road.
I am sure its louder that way, but between the tire noise, the engine noise, and exhaust rattle, I can't tell
(Yes, I know I busted both tow hooks off the truck, sheared the front bolts and bent the rear bolts. Back to the factory tie downs as tow points for me.)
