Results 1 to 6 of 6
Thread: Brake pedal/shifter release mechanism
    May 2010
    1999 Ebony 1716
    Without looking at it, I assume it's a simple ground/wire that sends some signal to the shifter button so I can shift out of park.
    I'm having problems with this releasing at start up, sometime I have to hit the break pedal 3 or 4 times before I can push the shift button in. Any suggestions? I'm out to investigate right now, maybe some help from any one who's experienced this before.
    May 2010
    1999 Ebony 1716
    I found a few threads. It seems it's a magnet that may be dirty, or the wire that's kinked somewhere. I'll report back soon.
    2000, Ebony, VX, 0370
    Thanked: 12
    Someone just went through this relatively recently, but it is a little solenoid switch that allows the shifter to move when the brake pedal is pressed. When the radio is off I can actually hear mine clicking when I hit the brake pedal. I'll do a search, but hopefully someone will chime in soon.
    *edit* - nevermind, looks like you've got it under control.
    Nov 2010
    1999, Astral Silver , VehiCross, 2547
    Wierd but mines does not need the brake to shift into gear but will not shift if the key is removed from ignition. Hmmm
    Feb 2004
    '01 Ebony #0830
    I made this video earlier this year to help those with this same issue.
    Hope it helps you too...
    http://www.youtube.com/watch?v=fHk2eTnW2lk
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    May 2010
    1999 Ebony 1716
    Sweet video!
  1. lubricating brake pedal
    By SlowPro48 in forum VX Troubleshooting...
    Last Post: 02/23/2010, 11:19 PM
  2. Door lock internal mechanism
    Last Post: 07/10/2008, 01:24 PM
  3. Brake pedal clicking...
    By kobie in forum VX Troubleshooting...
    Last Post: 06/06/2006, 02:38 PM
  4. Brake pedal squeak'n
    By ScottinMA in forum VX Talk...
    Last Post: 09/14/2004, 08:14 AM
  5. Brake Pedal Effort
    By Spy Hunter in forum VX Troubleshooting...
    Last Post: 02/20/2004, 09:57 AM
