Results 1 to 15 of 29
Thread: VXAddict's Addiction Therapy Log
    Nov 2010
    1999, Astral Silver, 0764
    Although I just purchased the truck a little over 2 weeks ago, I haven't had a chance to drive it much as it's been @ the garage getting some work done. After reading other people's work/mod log threads, I figured I'd create my own to catalog the progress.
    Unfortunately I'm not the most mechanically inclined person (unless you consider being able to slap together a computer from its separate components, or wiring up a home entertainment system and X10 home automation setup), so nearly all of the work will be done by my mechanic or other installers. I will try and post pics as it goes by.
    Thanks to everyone's contributions on this site for most of the product recommendations.
    As of December 28th, 2010 -
    172,000 miles
    - Replaced engine oil (Mobil 1)
    - Replaced PCV Valve
    - Replaced all spark plugs (Platinum 4)
    - Replaced serpentine belt
    - Replaced transmission fluid
    - Replaced transfer case fluid
    - Replaced front/rear differential fluid
    - Replaced driving/fog lights
    - Replaced headlights (Silvania Silverstar)
    - Replaced front driver and passenger floor mats (Goodyear)
    - Replaced windshield wipers (Rain-X)
    - Replaced all shocks (Gabriel Ultra)
    Ordered for installation after New Years
    - Replace Front L/R Calipers (R1 Concepts)
    - Replace brake pads (Posi Quiet Ceramics)
    - Replace Front Rotors (R1 Concepts Cross-drilled/Slotted)
    - Replace brake lines (Goodwrench Stainless-Steel Braided)
    - Replace brake fluid
    - Full alignment
    Next on wish list
    - Replace head unit and remove factory CD changer
    - Replace front and rear speakers
    - Install rear camera
    - Replace rear view mirror with video monitor
    Mar 2010
    '01 Kaiser Gray VX#0867
    Good to see all the pampering going on to a higher mileage VX. These trucks deserve to be a collector's vehicle and I am always glad to see new owners putting new life into these older vehicles.
    I took a Christmas break from the site and don't recall this exact vehicle, but have you changed the timing belt?
    '01 Kaiser SC'ed VX #0867
    Nov 2010
    Thanks - I just got the truck back while I wait for the brake parts. Frustrated that many shops are completely shutdown before the New Years!
    The previous owner told me that he had the timing belt changed around 140,000 miles along w/ the water pump. I figure I'm good until I hit at least 200k.
    I don't drive much given my work travel schedule (I'm usually on a plane). I figure I have a few good years until I hit 200k.
    Mar 2010
    Just make sure to keep checking that oil level. This is my second car that has issues with sudden oil loss, and on both this and the other site, some owners have thought that Mobil 1 was to blame. They all liked the oil, but it seemed that there was a high percentage of vehicles that had sudden oil loss, that also ran Mobil 1. But whatever you run, keep an eye on the dipstick at every fill up.
    Nov 2010
    Thanks for the heads-up. Yeah, I've definitely read the horror stories here. I've learned to check the oil and purchase a few extra PCV valves to replace every oil change.
    I did have a bit of a scare this morning. The check engine light came on about a minute after I started her and waited to warm up. I grabbed my phone and checked this site. Someone had mentioned having the CEL go on due to a untightened gas tank. I went ahead, tightened it up, and drove to breakfast. 1 hour later the CEL turned itself off and it's been fine since...
    I did notice my gas tank door is a bit loose. Not the gas cap, but the metal door itself - locking the door w/ the key prevents you from pulling it open, but there is certainly some play if I try to push the door inwards. Is that normal?
    Nov 2010
    I nearly forgot - I did two mods today. I was trying to figure out what to do w/ the Fuzzy Hole. Spitfire5454 had a great idea in this thread: http://www.vehicross.info/forums/sho...min+fuzzy+hole
    I ended up mounting an old Garmin Nuvi 205 using some velcro onto the hole. It looks great and works fine.
    I also picked up one of these USB chargers for your cigarette lighter: http://www.belkin.com/IWCatProductPa...duct_Id=489767
    I can now plug in a USB cable to charge up either my cell phone or the Nuvi. I recommend these things to anyone who carries around USB-powered gadgets.
    99" silver Vcross #1307
    Yo guy I bought my VX end of 99 brand spankin new still have it , has 196,458 miles I'll die with mine!!
    Quote Originally Posted by Cris View Post
    You should post up in the 10 year section. Love to hear these great stories by the original owners..
    Jan 2011
    2001,proton yellow,0631
    rear view mirror
    anyone raised the rear view mirror from its stock position to improve rear visibility?....and surprise surprise..who'd a thunk there'd be interior lights in the rear view mirror...man i love this thing....didnt think anything would come near winning my affections as much as my Boxster
    Nov 2010
    Well - it looks like all of my new front brake hardware (calipers/rotors/etc) has finally arrived at the garage. I'm dropping her off at the garage in the morning and I hope to get her back in a day or two. Of course my timing is perfect (NOT) - it looks like we might be getting some snow while she's in the shop...argh!
    Nov 2010
    So I got the truck back on Friday and have been driving her all weekend.
    Front Brake Impressions: The thing stops on a dime. No squeeking, and the pedal travel seems much better. I think there's some break-in period for the pads and cross-drilled rotors, but I'm happy. My mechanic said the originals were rusted onto the hub pretty badly. Happy w/ the new hardware.
    Alignment: The truck pulled to the right pretty hard before, particularly when I stomped on the brakes. That's what led to the brakes overhaul. Now that that is taken care of, the only thing I still have is a slight drift to the right when the steering wheel is at dead center. What's odd is when I let go of the wheel, the car tracks straight - so I'm thinking the steering wheel itself needs to be checked? Also, noticed there is still a bit of 'play' when i turn the wheel an inch or two to the right or left and nothing happens...
    I'm currently at Best Buy getting the head unit and speakers done. I'll post pics when it's all finished!
    Nov 2010
    So the Best Buy guy installed the front speakers and the new Alpine head unit. The system sounds fantastic, and the radio adds a nice bit of 'modern' look to the outdated dash. The IPOD interface is nice too.
    There's only one problem (well, lots of small ones)... (sigh)
    My turn signals, the hazard light switch, the rear defroster button, (basically any dash button to the right of the gauge cluster) doesn't work. I'm hoping he just accidentally disconnected something as he took off the dash to install the radio, or maybe a fuse blew?
    Most everything else electrical works, headlights, gauge cluster lights, windshield wiper, etc.
    Going to give him a call tomorrow and tell him to fix this ASAP.
    Another problem you're having... NO PICS!!! Too many words, not enough photos!
    Quote Originally Posted by vxaddict View Post
    The alignment shop should have taken care of centering your steering wheel when they did the alignment.
    The play in the steering should be able to be adjusted out. There is a set screw on the top of your steering box that adjusts the backlash on the gears in your box. It's an easy process & there should be a thread or 2 on the process.
    Edit:
    Here's one: http://www.vehicross.info/forums/sho...=steering+play
    Nov 2010
    LOL - message received. The car's been in and out of garages/install bays lately, I haven't had time to take pics. I will do so by my next update, I promise.
  1. Action Figure Therapy
    Last Post: 12/09/2022, 09:07 AM
  2. Addiction Continues
    By simonsayz1 in forum VX Talk...
    Last Post: 12/09/2016, 06:50 PM
