Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Help, check engine light, low oil
  1. #16
    Quote Originally Posted by mindaugas View Post
    It was more than an 1/8 inch on the dipstick before I added. After I added it was at the full mark. I checked it twice over the 450 miles,
    Just trying to clarify what your oil level was....
    ~Are you saying the oil was 1/8" DOWN from full on the dipstick?
    ~Or ONLY 1/8" showing at all on the dipstick?
    If it was only 1/8" DOWN, then you wouldn't need to add a full quart.
  2. #17
    Jun 2007
    2001, Proton
    interesting question
    I have always beleived that the range on the dipstick from bottom full to top full was a quart of oil so anything below that range could fit a whole quart without being overful.
    Carter Pewterschmidt
  3. #18
    Oct 2004
    2001, Yellow (PROTON) VX, Supercharged
    Regarding the 'engine light', usually it's the egr valve or failing gas cap or one that hasn't been tightened correctly.....ya' know the 'three click' correctly tightened thing. EGR valves are expensive though at around $150+ but they can easily be cleaned right in the good ole' home garage.
  1. first check engine light
    Last Post: 04/26/2010, 07:36 AM
  2. Check Engine Light
    Last Post: 11/01/2007, 05:57 PM
  3. Check Engine Light
    Last Post: 10/29/2007, 01:25 PM
  4. Check Engine Light...
    By dobie3 in forum VX Troubleshooting...
    Last Post: 12/11/2003, 02:45 PM
  5. Check engine light just came on...
    By Inaba in forum VX Troubleshooting...
    Last Post: 06/28/2003, 10:52 AM
