Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: Salt on Roads
  1. #16
    1999, Ebony Black, VX, 1614
    Quote Originally Posted by AlaskaVX View Post
    We haven't used salt in AK for 10 years I think.
    Cuz the food is just that good?
  2. #17
    Feb 2008
    2000 Proton yellow 0802
    That's weird that NV is on there. They DO NOT salt here in Reno, not as long as I have been here. Typically, they spray the roads with some sort of fine gravel to add traction, but I have not seen any salting on city streets or highways.
    Nevada dot
    NDOT road weather information
    systems pinpoint roads needing
    salt, sand or brine, greatly
    reducing use of all three products.
    d State-of-the-art, computerized salt
    and sand spreaders allow extreme
    precision and efficiency of salt/
    sand use.
  3. #18
    Yeah, maybe it depends on which municipality, but here in Reno they just spread sand, I have not seen salt.
    Dec 2010
    1999/White/Ironman VX/0940
    In NC where I live they have been using salt since I can remember but this year they started using some type of sprayable liquid and they coat the roads with it whenever we have a chance for snow. Not sure what chemical it is but might be better or worse than salt I dono
  5. #20
    Aug 2010
    01 Foxfire Red Mica VX 0441
    Just to add to this thread instead of making another about rust, how much rust is too much and when should I start doing something about it? I was actually thinking about having a body shop take off my axles and such and having them sand and grind off as much rust as they can and then using por15 or some other rust prevenatative on it. I realize this might be very pricey, but would make a huge difference on looks and possibly prolong the life of some of my parts. Anybody else gone to this extreme on their VX or car?
    2001 VX
    Mods
    2008 HUMMER H3
  6. #21
    Jun 2007
    2001, Proton
    Very extreem
    If I recall POR 15 actually changes the chemical structure of rust and seals to prevent future rust
    Carter Pewterschmidt
  7. #22
    Nov 2011
    2001 Proton Yellow #1214
    It changes to black oxide if I recall.
    81 AMC SX/4 "Go Mango Orange", 99 Vx "Astral silver",01 Vx "Proton Yellow", 02 H1 "Competition Yellow" and "lil pigglet" 05 Zuma "Team Yamaha Blue/White"
  8. #23
    Jul 2009
    It's not really the driveline and/or frame and suspension components that you should be worrying about. Sure, they may look bad with some surface rust, but they are all of such a heavy gauge steel that rust-through is unlikely in all but the most extreme of cases. The body panels, seen and unseen, are the most prone to rust-through and should be protected accordingly. Thorough washing and treatment of all metal parts, whether frame and suspension or body panels is the only way to slow the ravages of winter. Not driving a vehicle at all in winter is the only sure-fired way of keeping rust at bay. WD-40 is an excellent rust preventative when applied after every wash during the salty season. Priming and painting ANY exposed metal should always be your first line of defense...
    Vixer Fixer
  9. #24
    Aug 2010
    So you don't recommend the sanding and/or grinding it off by a professional body guy?
  10. #25
    Jul 2009
    If you've got the cash and the surface rust on the undercarriage bothers you that much, have at it. For what you'll get in return, I believe you're better off tackling that job yourself with some Rustoleum to shine things up down there and prevent further surface rust on the frame, etc.. Save the cash for things topside that are far more noticeable and by all means, keep 'er clean and shined all over to slow the decay. WD-40 really is an effective and affordable way to slow or stop rust and it makes everthing look clean and shiney and it stops squeeks. I periodically get under all my vehicles with a big ol' spray bottle of the stuff and spray it all down. I buy it by the gallon and use it in hand sprayers. It softens dried out rubber too and it will not harm paint, wiring, plastic or anything...Sure makes the cladding look nice! I shoulda bought stock in that company...
  11. #26
    Oct 2003
    1995 Isuzu Trooper LS
    My 93 Trooper has no rust on the body but the frame is rotted...it was a Massachusetts car.
  12. #27
    Aug 2010
    Ok, So basically just get under there and spray it with WD-40? I'm gonna have a professional check it out anyway to see what he thinks. Maybe i'll take a pic and post and see what you think. I'm off tomorrow so maybe then.
  13. #28
    Jul 2009
    I had a '86 Mazda B2000 Ext Cab that looked immaculate on the outside, yet the frame was rusted through in all kinds of places. It does happen, that's why I tend to keep everything well-washed and sprayed down with "the WD" so as to not see that sort of thing again. For the record, I bought the Mazda that way for a mere $400.00 as a winter beater and she served me well, right up until the time I snap-rolled it three times and yet the frame still didn't break, amazing...
  1. IRT deadliest roads
    Last Post: 10/07/2010, 02:35 PM
  2. Rain + Wet Roads + 2wd = :)
    Last Post: 06/01/2009, 07:16 AM
  3. Salt Lake City Convoy
    By rowhard in forum Moab 'Zu XII May 12, May 16, 2009
    Last Post: 05/11/2009, 09:25 AM
  4. Salt Lake City, Utah Meet and More
    By ZEUS in forum Meets...
    Last Post: 07/27/2008, 09:59 PM
  5. Salt Lake City assistance
    By So-CalVX in forum VX Talk...
    Last Post: 07/09/2008, 09:53 AM
