With many flashers, leds will cause the turns signals to flash rapidly, or not flash at all. If using leds for turn signal applications, or in vehicles with bulb-out warning systems, like Audi, Volvo, Mercedes, BMW and others, you may need to add load equalizers. For led turn signals, you can change the flasher out using one of our new patented combination led/oem bulb flashers if we have one that fits your vehicle.
Unfortunately, there are no application charts for the flashers. The simplest way is to match the blades of the one you have to the images on the web page to see if we have one that matches. You can find the flasher by switching on the turn signals and finding where the clicking sound is coming from.
If we do not have an led flasher that matches, use one 6 ohm load equalizer installed across the - ground wire and the + turn signal wire feeding each led bulb. Use two 6 ohm equalizers for two front, or two rear led turn signal bulbs. If you have four led turn signal bulbs in the front or rear, use two 3 ohm and position the load equalizer across the wire that feeds both bulbs. In some cases, if the front and read turn signal bulbs are powered from the same circuit, one 3 ohm on each side will take care of two led turn signal bulbs, one front and one rear. The only way to know is to try it and see. One 6 ohm at each led turn signal bulb always will work though. Place one load equalizer at each led turn signal bulb. For turn signal led bulbs, the equalizer must be spliced across the - ground wire and the + turn signal wire feeding each led bulb.
More details on load equalizers can be found at:
http://autolumination.com/equalizers.htm
