Ryan--- thanx for sharing the website link!!! Yes, the V-LEDs website has some pretty cool LED bulbs in many different colors. However, for a 194-series LED bulb (wedge-type) that fits in our factory VX fog light housings I have some negative concerns, they are:
194-series (wedge-type):
o $10 each per LED bulb versus $1.25 each for the 18-watt MALIBU.
o Low Brightness Output Wattage for LED (2-Watt & 5-Watt) versus 18-Watt High Brightness Output for MALIBU.
o The 194-series LED bulbs are mostly used as showcar "marker" lights and do not project a viable projector light beam onto the road surface versus MALIBU has 18 watts of illumination power to be "projector" beam in VX fog light housings that illuminate the road surface.
o LED's may require a seperate "recifier" be added within the wiring circuitry in order to operate versus MALIBU is simply plug-n-play incandescent like OEM without any modification to factory wiring/circuitry.
For me, I'll stick with the much cheaper and much brighter plug-n-play MALIBU 18-watt bulbs without any of the circuitry hassles that sometimes come with LED's.
