Results 1 to 15 of 26
Thread: Drop Differentials
    2001, IronMan White, #440
    Wrench Drop Differentials
    I've got my torsion bars cranked and bigger tires. Thus, I've torn four CV boots.
    Here's my question. Those that have used a dropped differential did that stop the problem with the torn boots?
    Thanks.
    It sure cured it for me.
    Now I'm just waiting for RCV Performance to make the replacement half shafts available.
    Others that have had them installed for a while are:
    BigMeat
    LittleBeast
    CSTYLES
    & others that don't come to mind at the moment.
    I wonder... how high do you have to get before you start tearing CVs? My tires are only 1" taller than stock, but I'm considering a pair of 1.5" Daystar spring spacers (and the accompanying t-bar crank). Do you think that necessitates a drop?
    Unfortunately, there is no rhyme or reason that we can tell right now.
    Some crank 'em & tear them, some don't.
    If you're lifted & start tearing boots - they'll keep tearing (no matter what brand of boots you replace them with) until you do one of two things: diff drops or replacement half shafts.
    BTW, you should be OK with 1.5 in lift. Troubles seem to start at 2-3 in lifts.
    01, LineX tan/black, 1055
    Tom,you forgot me!! LOL.
    I never tore my OEM boots, went ahead and put the super $$$ mecatechs on while doing locker install. Tore those boots in just a few months.
    Now that I dropped the diff, no problems. I was somewhere in the 3" lift I suppose.
    VT, bigger tires doesn't mean anything, and has ZERO effect on the CV angles. Only when you get into cranking the Tbars does it matter.
    Another bonus for diff drop, your CVs are almost dead level, which means the force is more evenly distributed to all the balls in the cup and in the outer joint as well. That cannot be a bad thing. Otherwise, that force is concentrated on two or three balls at a time, and that cannot be good. I would suspect far less CV wear and tear with the diff dropped.
    (Tom, I know this is a repeat of what I told you via PM, just wanted to post my thoughts so others could read it as well)
    There is one disadvantage. If you lower the front back down (which I have now done), it puts the CVs at a negative angle(in reference to the normal lifted angle), and they DEFINITELY don't like that. They weren't meant to ever sit like that. So, I have to compromise and lift the front back up a bit to relevel the CVs. I found that the offroad performance was much better lowered, and I had no problem with the 34s fitting. Did some cutting and pounding, but my rig is more for offroad now than anything else. It looks kind of goofy, the rear sitting much higher than the front, but I will take the performance over the cosmetics...as you all know
    I read in one of rickshaw's threads that although the Daystar spacers claim 1.5", they only actually raised his rig 1". So hopefully not a lot of cranking is required.
    Tom - Since you've seen/installed my Kilby plates first hand, would a diff drop interfere with them? Seems very likely to me...
    Sep 2010
    2000,Ebony,VEC,0013
    Dropping my front differential has made a wonderful difference for me. The angle of the half shafts -esp on the passenger side - was so acute that the tripod style cv would give a slight upward push on the diff with every rotation of the front tire. this happened esp when the front end would dip from a bump in the road while traveling. I had an intermittent bump brump noise that was solved by dropping the differential to where the half shaft is much more horizontal. As I type this I'm expecting UPS to walk in with a used driveshaft. I have a lot of driveshaft noise- long story- that expect to fix with it.
    2000 IronMan #11
    I have had my diff dropped for a couple+ years now.
    No torn boots.
    IIRC we've been doing a drop of 2" which does require you to relocate the crossmember. That crossmember is what the Kilby's bolt to at the first seam (front to back).
    I don't remember how much clearance there is before dropping but I'm thinking that if you only drop the diff 1" then it might work.
    Don't nobody run out & measure the clearance on an unmodified VX though. He has the Kilby plates which comes with a replacement crossmember.
    If you do decide that it's necessary to drop the differential though, I'm sure that if we only go for the 1" and the pumpkin hits the crossmember, we can modify it to still work with the Kilby's. In your application, the crossmember is only something to bolt to. The plates themselves are far stronger than the crossmember.
    Oct 2003
    1995 Isuzu Trooper LS
    The Daystar spacers in question are designed for the IFS of a Dodge pickup...because of the placement on the control arm the spacers achieve 1.5" due to the radius of the control arms, in that application. Whereas for a straight up, solid axle application like ours it is a 1" spacer.
    Jan 2011
    Searching...
    Where exactly can one purchase the items needed for a differential drop?
    Quote Originally Posted by DogBoneVX View Post
    You need to know somebody that knows somebody that knows the secret handshake.
    Jan 2007
    VX Skeleton owner
    Thanked: 6
    You can make your own if you're willing to eat the downtime on your VX. They are pretty straightforward. IIRC there are a couple of people on this forum that have offered them in the past. Try searching.
    Jan 2011
    Searching...
    I could search, but then I would be doing this forum a disservice by not providing content.
    What exactly does IIRC mean?
    May 2010
    1999 Ebony 1716
    indigo indigo rivera charlie... maybe?
  1. diff drop
    By ramathorn in forum VX Troubleshooting...
    Last Post: 08/23/2012, 01:31 PM
  2. Drop in MPG's
    By crager34 in forum VX Troubleshooting...
    Last Post: 02/14/2011, 08:00 PM
  3. differentials
    By etlsport in forum General Tips...
    Last Post: 02/16/2007, 10:09 AM
  4. Sudden Drop In Mpg
    By DK in forum VX Troubleshooting...
    Last Post: 01/11/2006, 04:51 PM
  5. gas mileage DROP!!
    By rainee25 in forum VX Modifications...
    Last Post: 10/31/2004, 08:25 PM
