Results 1 to 4 of 4
Thread: MAF Sensor
    Dec 2003
    Former Owner 0216
    MAF Sensor
    I had a diagnostic run on my VX to see if the pros can find anything that may have brought my MPG's down (from about 16-17 to 12-13). I did run Sea Foam through the system and it seemed to boost it up a bit, but no more than 14. One of the issues they said that may be at fault is, I am missing the Screen before my MAF Sensor. I have cleaned it a few times and have never seen one, have looked online and see where there are some sensors that do have the screen and some that don't.
    Do we have a screen or not??
    2000, Ebony, VX, 0370
    Thanked: 12
    If I remember correctly mine has a screen. The screen is probably 1/2" thick and has honey comb shaped holes. I could probably get a picture of it for you tonight.
    May 2010
    1999 Ebony 1716
    I know the screen is VERY important. When I had the Mach 1 if the screen got rotated because of me moving things around it would affect how the car would idle so much that it would die at any speed if I lifted the throttle and took the car out of gear. In the mustangs I think it created a certain flow or spiral or something when the air passed through it and then through the MAF sensor. I'd try to source one for sure, hopefully could find a wrecked VX and get the part for cheap.
    Maybe could fit one from another vehicle that shares the same MAF set up, I think the Axiom is the same engine, or close. Is that right?
    Dec 2003
    Former Owner 0216
    Mark - Thanks, but no need for the picture. I seen a few online and see where it would go. I will be trying to find one starting......
    NOW!!
    Thanks for the help peeps. (I know....I can't really pull that word off very well)
  1. Which O2 sensor is Bank1 sensor 1
    By Ebenezr in forum VX Troubleshooting...
    Last Post: 08/05/2014, 05:55 AM
  2. MAP sensor
    By IronManVC in forum VX Troubleshooting...
    Last Post: 03/13/2012, 05:50 AM
  3. re abs sensor?
    Last Post: 02/24/2012, 01:31 PM
  4. O2 Sensor/Coolant Temperature Sensor
    Last Post: 04/21/2007, 12:50 AM
