Results 1 to 8 of 8
Thread: Does yours clunk??
    Dec 2010
    2001,black
    Angry Does yours clunk??
    While coming to a stop both mine and my Dad's truck clunks just before we stop. I have an 01 and my Dad has a 99. The noise is coming from the rear end somewhere. Any ideas what that is?? Thanks
    1999, Ebony Black, VX, 1614
    Search: "Clunk"
    Here are some things to get you started...
    http://www.drivehq.com/file/df.aspx/...aats/clunk.gif
    I believe what you are experiencing is caused by "Driveline Lash"
    .....and its "Normal"
    Lubing your U-Joints seem to help some folks.
    yes its very common. the two normal causes are an improperly greased driveshaft/u joints or missing transmission mount bolts.
    first place to start, grease all 3 zerk fittings on the drive shaft
    then, while your under there, check the back of the transmission at the crossmember. make sure there are two bolts holding the transmission in place
    Jul 2004
    1999/black/VX/black
    X2 on the trans bolts
    http://www.vehicross.info/forums/sho...ns+mount+bolts
    Quote Originally Posted by vx2001 View Post
    You both have VX's? Is your Dad registered here separately?
    Now that I've dispensed with the lead-in, here's the real question:
    Who's your daddy?
    Sep 2010
    2000,Ebony,VEC,0013
    I have occasional "knock" under my rt foot somewhere. I think it is a loose transmission line or something. There is an entire writeup somewhere on this subject and I think its by isuzu. There is a link somewhere at this website.
    99" silver Vcross #1307
    mine went clunk rite befor the trans went
  1. Transmission Clunk from 2nd to 3rd
    By kpv in forum VX Troubleshooting...
    Last Post: 11/03/2013, 06:56 PM
  2. Brake Clunk
    By haggisgood in forum VX Troubleshooting...
    Last Post: 06/16/2010, 06:20 AM
  3. Clunk and Noise
    By ThunderChicken in forum VX Troubleshooting...
    Last Post: 07/28/2004, 08:38 PM
  4. Rear Clunk
    Last Post: 05/04/2004, 10:10 AM
  5. Downshift Clunk!!!!
    By xdfarrx in forum VX Troubleshooting...
    Last Post: 03/04/2003, 07:23 PM
