Results 1 to 14 of 14
Thread: zinc drilled and slotted rotors
    Oct 2009
    2001 Mica Green VCS 0403
    I am looking to replace my OEM rotors with drilled and slotted zinc ones. Ebay has many to choose from ranging from $150 to $250. Are any better than the next guys, or should I just go with the least expensive.
    When I tackle this project should I expect any issues with senors, rust, etc.
    Thanks,
    Soggy
    towards the end of summer i replaced Spike's rears with R1 concept premium slotted rotors. They seemed very well built, and had a very nice black coating over all of the non machined surfaces. along with Napa Adaptive1 pads, he was happy with the results, just saw him on Tuesday and they seem to be holding up nicely, a very slight bluish hue to them, but still smooth and quiet
    didnt have any issues other than the guide pin for one of the calipers was really in there tight, using a 12 point socket started to round it off, but i switched to a 6 point socket (which i should have been using in the first place..) and it came out no problem. I had him spray everything down with some WD-40 the night before, so that may have helped.
    If you want some help let me know, id be happy to come down, and I can bring those floor mats too!
    Jun 2007
    2001, Proton
    I also used the
    R1s no problems and good quality and price on ebay
    Carter Pewterschmidt
    Quote Originally Posted by soggybottomboyz View Post
    You'll need the Isuzu hub bearing tool get the old rotors out. I ordered it off ebay for less than $20 shipped.
    ...and like etlsport said- spray the bolts with PBblaster/WD40 a couple days before
    2000, Ebony, VX, 0370
    Thanked: 12
    I used SP Performance drilled and slotted rotors and stock Isuzu pads and haven't had a problem with either of them at all.
    If you can't find the Isuzu hub bearing tool then you can alter a Ford (I believe) hub bearing tool. I altered the Ford one and have pictures if you want to see what's up with that.
    Also, if you haven't seen it yet read through Kenny's thread on replacing the rotors and repacking the bearings. I had that and the instructions from Planet Isuzoo and everything went smoothly and easily.
    Jan 2008
    1999 Astral Silver 0481
    I am on RI concepts too.
    All i say .....go get them
    Dakar was just the begining.
    2001, Ebony Black, 1153
    Oct 2009
    Thanks everyone. Do I need the hub bearing tool if I am just replacing the brakes & rotors and not the bearings? I need the brakes now, was hoping to do the bearings in the fall?
    IIRC, the bearings get service by default when replacing the rotors. I'll have to read the instructions to verify but the bearings should be either press fit or machine fit to the hub of the rotor.
    Thanked: 12
    You will need the hub tool to remove the nut holding the rotor onto the spindle. You will also need it for re-assembly, as well as a scale to determine pre-load on the nut so that you don't crank the nut down too much and bind the rotor up which would result in HORRIBLE gas milage.
    The bearings literally just drop into the rotor. No pressing necessary. There is a seal that goes in behind the bearing at the back of the rotor, but the front one is held in when you sandwich the whole assembly back together.
    I would strongly suggest reading this: http://www.vehicross.info/forums/sho...bearing+repack It gives a step by step how-to on replacing the front rotors and repacking the bearings. There is a link in that thread to a how-to over on "The Planet" and that write up lists the tools and expendables that you will need to do the job right.
    Oct 2009
    I picked up 4 zinc plated drilled and slotted rotors and ceramic brakes for $150 off ebay. Napa had two grades of bearings the best set will cost me $255 for the bearings, races and seals. I hope misc. should be around $50 (grease, cleaner, rtv sealer, etc). A buddy of mine has access to a bearing press to install the bearings into the hubs. Looks like every thing is falling together for this project to happen in a couple weeks.
    Question: Do I really need a fishing scale to neasure the pre-load for hub nut or will a torque wrench get the job done?
    Thanks all for the help,
    Soggy
    Jan 2008
    Arrow
    Soggy
    Probably no,however for torque specs go check the VX repair manual,you can either print it or burn it into a CD,downloaded to flash drive/SD card if you got a lap top to carry it with you while working on the horse.
    Thanked: 12
    You'll need some kind of scale to determine pre-load. A torque wrench will just get the nut tight, but not be able to tell you how much force it takes to rotate the hub. I was a little confused about that part too, but now that I've done it a couple of times it makes sense. You use the spring scale to pull the rotor around to make sure that the hub nut is tight, but not too tight. Too loose and things could move around killing the bearings (or some other catastrophic failure), and too tight will kill your gas mileage.
    Also, you don't need a bearing press. The bearings just drop in and are held in place once everything is tightened down. To get the bearing seal in at the back of the rotor I just used a 2x4 laid flat across the seal and then gave it a good whack with a rubber mallet. Seats the seal in nicely.
    Oct 2004
    2001, Yellow (PROTON) VX, Supercharged
    R1 Concepts for me!
    Go with R1 Concepts! Great product. I posted about them back on 1/23/11 and I had my 'bee' out a couple of times lately since the weather is breaking around here in my part of MI. I got a great price and did other stuff like bearings, seals, while I was at it. I'm EXTREMELY HAPPY with the results AND they were very affordable. I also used silver 'high heat' paint on the non-machined surfaces and used 'proton yello' on the calipers to match my
    'bee' . Looks cool! Look for the 'deals' as they come up 'on-n-off' at R1.
    Below is my orignal post:
    New Rotor and Brake Pad Install - It's Great!
    I just finally replaced my stock rotors with R1 Concepts Cross-Drilled/Slotted Rotors front (#EDS-43013) and rear (#EDS-43015). Since I typically lay up my VX during the winter months this was a great time to get this done. I used Hi-Temp 1200 degree paint on all the non-machined rotor areas and decided to use the EBC 'Ultimax' SUV performance pads too (#UD579-FRONT/#UD580-REAR). Went and replaced inner/outer bearings, races, and seals while I was at it and I could not be happier with this combination! The Bee stops unbelieveaby better! Total cost for parts, paint, etc. was less than $700.
    It was the best procrastination I ever subjected myself to in recent history. I usually take 'forever' to make decisions on stuff like this. If you're considering brake upgrades for the VX, this is a great combo!
  1. R1 Concepts Drilled/Slotted & Painted Calipers
    By snowtrooper1966 in forum VX Modifications...
    Last Post: 06/24/2008, 03:14 PM
  2. Cross Drilled or Slotted Rotors??
    By Lizardmen3477 in forum VX Modifications...
    Last Post: 08/27/2007, 07:24 AM
  3. Slotted rotors
    By Andrey in forum VX Talk...
    Last Post: 04/24/2006, 10:38 PM
  4. Gold or Black zinc plated rotors
    By Raque Thomas in forum VX Modifications...
    Last Post: 06/18/2005, 01:34 PM
  5. Drilled and Slotted Rotors ???
    By psychos2 in forum VX Talk...
    Last Post: 02/08/2005, 07:49 AM
