Results 1 to 2 of 2
Thread: Questions about engine cooling fan?
    99' Astral Silver
    Aloha fellow VX'ers
    I've noticed that the fan on my VX doesn't seem to come on at all after shutting her down. It does spin on it's own with the engine on and moves freely back and forth when when the engine is off. Should the VX fan come ON to cool things down even after shut off?
    It's been so long since I've heard it come on that I can't remember?
    Also, I read numerous posts on the fan clutch going bad, but I'm not over heating and temp gauge stays normal smack dab in the middle. Scan gauge temp usually reads about 180 here in hawaii.
    Just curious if the fan should come on even after shutting her down?
    Live Free or DIE!
    2000, Kaiser, #0016
    Obvious answer:
    The fan should not run if the engine is not running unless you have installed an aftermarket ELECTRIC fan which may or may not be activated by coolant temp depending on the features of the aftermarket fan(s).
  1. Cooling Problem - Interior & Engine
    Last Post: 06/28/2008, 08:39 PM
  2. Engine Failure Questions
    By t2p in forum VX Troubleshooting...
    Last Post: 03/23/2004, 02:31 PM
  3. Cooling Fan Clutch
    By ojmagg in forum VX Talk...
    Last Post: 12/29/2003, 08:10 AM
  4. Engine Rebuild - Questions
    By Whaleboy in forum VX Troubleshooting...
    Last Post: 05/20/2003, 08:04 PM
  5. Replacement cooling fan
    By David Wiltshire in forum VX Modifications...
    Last Post: 04/28/2003, 08:50 PM
