Just got my VX aligned and was told I have a bad camber issue. It has always pulled a little to one side but nothing major, but after this last tire and wheel swap it was worse than ever.
My right side was -0.9 and is now only -0.7.
I am lifted and have NOT flipped my ball joints. I could not tell if this would help or not from the posts I read. Seemed like a couple said it would produce positive camber which I would think lower the negative stance but I read another that said they un-flipped after gaining too much.
Needing a little bit of advice.
