Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Front skid- pics of lower attachment points
  1. #16
    IDEA!!! Ding Ding Ding Ding!
    Tried getting the lower front skid bolts in...no luck yet...BUT, had a brainstorm while lying there staring at it!
    Forget using the existing holes completely!
    ~Drill completely NEW holes in the FLAT section of the skid, right next to the the raised area where the current hole is. Then also make a new hole into the cladding in direct alignment. Note in this area how the plate AND the cladding are very close together...will be so easy to drill new holes there.
    (Suggestions for pilot hole size or technique on this ABS plate??)
    ~They're about 3" - 4" away from the original holes.
    ~There's some room behind that area of cladding so I can easily get a washer and a nut on, OR
    ~Buy some "retaining clips" (just like the two in the license plate area hold the top of the skid in place.) Slid it over the bottom edge of the cladding.
    ~These clips give the screw some threads to hang on to, and spread the forces out over the clip, making it maybe a bit stronger (?)
    ~There's 3 flat sections along the bottom of the skid, put a screw/clip/nut in each one. Plate will have a total of 5 screws now instead of 4.
    WILL IT WORK???? Thoughts??
  2. #17
    Sue - check your PM.
  3. #18
    2001, Dragon Green, 1342
    Sue, think what ever one is saying must be so, the bracket is bent. I also had somewhat of a time with mine (one of Ron's). What I have done in the past, is just start the bottom two bolts to hold everthing in place, then pressing in the center with the knee, the curvature would open up enough to get the license plate bolts started, then tighten them evenly. Have it warmed up to make it more supple. That said, I think maybe bring the bracket forward will help, but try this before you go to the trouble of taking the front cladding off.
  1. How to Lower Front Seat
    By mrtew in forum VX Modifications...
    Last Post: 12/29/2012, 05:30 AM
  2. I fixed the rust at my rear wing attachment points
    By deermagnet in forum VX Troubleshooting...
    Last Post: 03/07/2012, 03:00 PM
  3. Pics of front & rear skid plates (by Ron)
    By VX KAT in forum VX Modifications...
    Last Post: 11/23/2010, 03:28 AM
  4. My front lower bump stop solution
    Last Post: 07/01/2009, 02:00 PM
  5. REQUEST: Skid Plates (with pics!)
    By IsuZOOM in forum VX Modifications...
    Last Post: 04/13/2003, 03:08 PM
