Results 1 to 5 of 5
Thread: Where to locate the VSS on a 2000 VX
    Mar 2011
    2000 Black
    I am installing a stereo with a Nav System and I need to tie into the Vehicle Speed Sensor wire which I believe in behind the vehicle cluster. I check the electricle troubleshooting document in the download section but unless I am mistaken it didnt have a diagram of the back side of the cluster. In tied into a pink wire because the instruction says that it will most likely be pink
    '99
    This is from my '99 shop manual. A '00 is probably the same. It looks like you want the lightgreen/white wire that comes from the VSS. You should be able to find it at the H-13 connector above your left foot or at the B-5 connector on the back of the meter cluster or at the D7 pin on the white, 32-pin connector on the back of the PCM.
    I hope this helps.
    Mark
    Feb 2011
    2000 Dragon #0274
    Deermagnet, that was the best, most concise response to a question ever. Kudos
    Junster If it don't looked fixed.. It ain't fixed.
    Mar 2011
    2000 Black
    Thank, I will try it out this weekend but it looks like what I am looking for. Ill let you know.
    What kind of head unit are you installing?
  1. Call me Mr 2000
    By circmand in forum VX Talk...
    Last Post: 07/24/2010, 08:14 PM
  2. $2000 for a VX...????
    Last Post: 08/03/2006, 07:44 PM
  3. I need a 2000 VX alternator!!!
    By egamo in forum VX Troubleshooting...
    Last Post: 02/05/2006, 06:15 PM
  4. 2000's on a 99?
    By nyc #1 ironman in forum VX Talk...
    Last Post: 07/06/2004, 09:42 PM
  5. Warrenty, 2000
    By Apostle in forum VX Talk...
    Last Post: 10/13/2003, 10:54 AM
