Does the VX share a rear sway bar with any other zoo's? I realize ours may be thicker.
As you can probably guess, mine has snapped in half at some unknown time.
So, according to Calmini, it would appear that the 92-04 troopers share our swaybars. Does that sound correct?
that sounds about right. I was under a 95 the other day taking bump stops off and noticed the rear swaybar bushings looked about the same. try looking up energy suspension too and see if their swaybar bushings match the vx?
looked through my computers at work...
rear swaybar links match
97-02 Trooper
96-99 Acura SLX
no listing on swaybar or bushings
