Results 1 to 14 of 14
Thread: Jack Stand Preference?
    May 2004
    2001, Ebony Black, VehiCross, 0432
    Question Jack Stand Preference?
    Hello everyone,
    While I am waiting for my newly purchased VX to arrive, I am getting all of my parts / pieces in-order to start restoring her. I've got quite a bit of work to do, so I'm thinking about placing her on jack stands while performing all of the work needed. Anyone have any input on what Jack Stands are the best to use with the VX?
    Thanks in advance,
    Adam
    There are MANY variables to consider when choosing.
    1. What surface will it be sitting on? I have the old steel quad pod version but had to also get a set with a flat plate base since my driveway is asphalt. The legs of the quad pod will sink into the asphalt if you leave weight on it for long periods.
    2. What lift points will you be using? If you're lifting from the frame, you'll need taller jack stands. If you are lifting from axles or suspension arms, you'll need shorter ones.
    3. Get them plenty strong. As you are jacking the vehicle up, the majority of the vehicle weight can shift to a single jackstand. Once in place, the weight should distribute evenly though.
    4. A wide base is better for stability but makes the jack stands more difficult to store when not in use.
    May 2004
    tom4bren,
    Thanks for the info... I placed some comments next to your questions if this helps.
    [QUOTE=tom4bren;230434]There are MANY variables to consider when choosing.
    1. What surface will it be sitting on? I have the old steel quad pod version but had to also get a set with a flat plate base since my driveway is asphalt. The legs of the quad pod will sink into the asphalt if you leave weight on it for long periods. Epoxy Coated Concrete Garage Floor
    2. What lift points will you be using? If you're lifting from the frame, you'll need taller jack stands. If you are lifting from axles or suspension arms, you'll need shorter ones. Frame will be the lift points.... Anyone know how tall of a stand I will need?
    Maybe something like this...
    http://www.vehicross.info/gallery/sh...user/2623/sl/a
    but maybe not.
    What type of work are you planning?
    May 2004
    LOL MileHigh..... Probably a little overkill for what I am planning.. Here's a list of what I have on the "To-Do" list so far:
    1. Remove front cladding to:
    Replace Headlight Gaskets
    Paint Front Bumper
    2. Replace Upper & Lower Ball Joints
    3. Re-pack Bearings
    4. Paint Calipers
    5. Replace Radiator Hoses
    6. Replace PCV Valve
    This is what I have so far, probably more to add to the list as I read up on the forum.
    Quote Originally Posted by Child's Play View Post
    Paint Front Bumper
    3. Re-pack Bearings
    4. Paint Calipers
    For that work, I would actually lift on the rear axle instead of the frame, it will make things easier so you arent dealing with the rear suspension flex, and will allow you to use shorter jack stands
    May 2004
    Etlsport,
    So, I understand that I can put jack stands under the rear axle. What do I do with the front? I'm assuming I don't want any load on the suspension when doing any work to ball joints, etc... So, do I just put the front stands on the frame, or is there another way?
    yes, in the front go ahead and use the frame just behind the front wheels. The rear is a pain to support from the frame because the frame curves up over the rear axle so theres not much room to place a jack stand. just take care to not touch the brake lines/sensor wires that run along the axle. the tops of my jack stands are U shaped and makes this easier.
    these will tear up your floor if you arent careful. on ashpalt i usually put down a sheet of plywood under them to prevent them from digging in
    I measured 17" to the frame on the front of mine (lowest point just behind front wheels). I have a 3" lift and 33x12.50's though.
    Oct 2003
    1995 Isuzu Trooper LS
    If you are lifted I suggest 6-ton jack stands, they are a lot taller generally than the cheap 3-ton ones...on my Trooper the 3-ton ones are only good for under the axles, they won't reach the frame.
    That's why God invented bricks, cinderblocks & 2x4's
    And Doctors, Nurses, and Hospitals...
    Wrench
    I have 4 of these for home use.
    And 2 of these that I keep in the Moab trailer.
    Hey, me too
    + bricks, cinderblocks & 2x4s
  1. Stand up and be counted
    By Moncha in forum VX Roll Call...
    Last Post: 10/25/2024, 08:17 AM
  2. Jack This Thread!
    By ZEUS in forum Chit-Chat ...
    Last Post: 02/27/2014, 11:23 AM
  3. Probable VX Fam 4-20 wedding attendees, please stand up...
    Last Post: 06/22/2013, 01:02 AM
  4. Current Preference on 16" Tire Replacements
    By lasturbo in forum VX Talk...
    Last Post: 08/20/2008, 03:31 PM
  5. jack and jack stands
    Last Post: 09/23/2006, 11:55 AM
