I've heard differing opinions on that one, Sue. We have members on this forum who have alleviated their overheating symptoms by installing a 2nd fan. My truck doesn't overheat at all with the fans on, so I'd be hard pressed to believe the add'l fan is causing an issue w/blockage. It only overheats when the a/c is on.
Good to know. Guess I'll take the entire hood off
Just Power washed my rad.... couldn't believe how much crud came out!
My opinion is that the cooling system worked at one point in time. If it is no longer getting the job done, there is something in the system broke, clogged, etc that is preventing the system from working properly. There should be no "need" for custom fans and radiators...not that they are not nice and sometimes effective. Unfortunately finding the "broken" part can sometimes be a pita.
Think I found the culprit. A/C is spinning sllllllllllllllllllllllllllllllllllllllllllllllooo oooooooooooooooooooooooooowwwwwwwwwwwwwwwwwwwlllll llllllllllllllllllllyyyyyyyyyyyyyyyyyyyy. I'll be replacing that next week. Still wanting to chop up my hood, though
